07-12-2017, 07:29 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| 300,000 weight in Diff
Will the diff hold 300,000 or 500,000 weight silicone? I'm not looking to lock the diff(s) as I'm mainly bashing, but still want to kick the ass end around. |
07-20-2017, 01:38 AM | #2 |
Rock Stacker Join Date: Mar 2015 Location: Houston
| Re: 300,000 weight in Diff
I'm sure someone will correct me if im wrong, but I don't think that the diffs on the wheely king are properly sealed/meant to be filled with and/or hold fluid I'm pretty sure that something as thick as 300k-500k would stay inside the housings just because that range fluid is practically a solid If you fill the rear diff with it, it will act similar to a fully locked diff (fluid that thick, and given the WKs inherent handling/suspension/weight transfer shortcomings) - so with the truck having darn near zero diff action, the solid axle rear will happily break loose/loose traction/"kick the ass out" for you If you put that thick goo in the front diff, it will, of course, act very similarly to fully locked as well However, just like a racer would choose to setup a 4wd vehicle to make the front wheels pull the vehicle out of the corners in a straight line, a really tight front diff will also have the effect of pulling the rear tires along with the fronts…in a nice straight line…and thus minimizing rear wheel spin and minimizing your ability to "kick the ass out" So, if you want to intentionally tune the truck to have a loose rear end, I'd try the heavy diff fluid in the rear and just go with a quality grease in the front diffs so This will allow the front diff to transfer the power to the tire with the least grip, therefore causing the front wheels to not be very good at pulling the truck (at least while cornering, but the fronts will still do their job when accelerating in a straight line) In the meantime, the tight rear diff will dig in with both tires no matter what direction you're going and, because the fronts will have less grip, the rears will do their best to grab and pass the fronts In other words, the truck should be quite tail happy and be quite willing and able to fulfill your dreams of an ass end that's just itching to kick around Hope this helps! Sent from my Apple iPhone 7…which, as you know, clearly defines me as being superior to you in every way |
07-21-2017, 07:26 AM | #3 |
Great info. Thanks! Too bad they don't make a fully sealed unit as ideally I'd like to tune the rear diff with say 10,000-30,000 weight. For now I'll try 300,000 in the rear and see what happens and use some AW grease in the front. |
300,000 weight in Diff - Similar Threads | ||||
Wheel weight or diff weight? | PipeDreams | Tires and Wheels | 4 | 11-06-2008 05:20 PM |
1983 Lincoln Towncar with 1,300,000 miles. | BUBBA069 | Chit Chat | 2 | 08-12-2008 10:29 PM |
$300,000 watch that doesn't tell time... | BUBBA069 | Chit Chat | 16 | 05-30-2008 06:38 AM |
1,000 weight shock oil testing | JasonInAugusta | Videos! | 25 | 03-30-2007 12:02 AM |
Any one got $300,000 to blow??? | SiameseDog | Chit Chat | 2 | 04-05-2005 03:25 PM |
