06-24-2018, 05:06 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| MST Cush Drive(Slipper), perfect fit on Wheely King!!!
The MST cush drive is a perfect fit with no modification. This should prevent stripping gears all while not having to deal adjusting a slipper clutch. The stock spur cover can also be used. |
06-24-2018, 05:09 PM | #2 |
| Re: MST Cush Drive(Slipper), perfect fit on Wheely King!!!
A small spacer or a few spacers are needed for the screw the secures slipper assm to input shaft. You may also want to use 17t pinion to get back to stock ratio and to due this you'll need to elongate the motor adjustment slot.
09-18-2019, 08:01 PM | #3 | |
Quarry Creeper Join Date: Jun 2018 Location: Hampton
| Re: MST Cush Drive(Slipper), perfect fit on Wheely King!!! Quote:
Sent from my SM-G965U using Tapatalk | |
MST Cush Drive(Slipper), perfect fit on Wheely King!!! - Similar Threads | ||||
wheely king external slipper | the build master | HPI Wheely King | 3 | 08-27-2015 02:36 PM |
Will these fit a Creeper or Wheely King??? | mastathug0 | Newbie General | 2 | 05-21-2010 10:00 PM |
will this fit a wheely king | ericbrierton | Paint and Body | 17 | 04-02-2008 06:45 PM |
