02-23-2007, 08:13 AM | #21 | |
02-23-2007, 09:20 AM | #22 | |
RCC Addict Join Date: Aug 2005 Location: Akron
That is the hardened steel kit for the MT2. See how the pinion shaft and the pinion are one piece? I THINK this will still work but haven't checked. You won't need a seperate pinion shaft if you buy that setup. Quote:
Unless you are putting some SERIOUS power into these axles the stock pot metal gears are going to last. I ran the stock pot metal gears in my nitro MT with an OS .18 CV-R motor and as long as I had them shimmed right they held up. | |
02-23-2007, 09:56 AM | #23 | |
02-23-2007, 10:32 AM | #24 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
82.66 will build a whole WK axle, housing and all. screw buying the truck, i'd rather just buy 2 axles worth of parts. 170 for 2 axles vs 176.99 for the truck + 57.68 to 4wd it
02-23-2007, 10:45 AM | #25 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
Hmmmm $170 for Wheely King axles... or $150 for indestructible Twin Force Axles from RCP... Preach on brother Raptorman |
02-23-2007, 10:47 AM | #26 | |
02-23-2007, 11:31 AM | #27 |
Here are a few vids of punishment on the pot metal gears. My truck is the yellow/blue MT. I agree the hardened gears are better, I've just had no reason to upgrade. I have a new extra set in my box that cost me $10 for the ring and pinion and diff case. http://smg.photobucket.com/albums/v4...nt=MTVideo.flv http://smg.photobucket.com/albums/v4...edinaTrack.flv |
02-23-2007, 01:27 PM | #28 | |
RCC Addict Join Date: Jul 2005 Location: Provo
02-23-2007, 01:30 PM | #29 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
Tammies has rubber and metal shielded BOCA bearings for .99 cents each! |
02-23-2007, 01:48 PM | #30 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
I bought 2 WK's at the same time for $350 out the door. Converted one to 4WD to bash with and saved the rest for other projects. I now have a set of axles to build a crawler with after getting the needed parts from Tower and they are not so much. Think of all the uses for the extra parts, battery, radio gear, servo, speedo, shocks, etc. Good luck even getting the 4WD conversion set from HPI Europe... Part #87602 Bearings can be found cheaper anywhere... http://www.teamfasteddy.com/ $0.99 each http://www.avidrc.com/ $1.00 each Last edited by themerc64; 02-23-2007 at 01:50 PM. |
02-23-2007, 02:07 PM | #31 | |
Pebble Pounder Join Date: Jan 2007 Location: So.Cal
02-23-2007, 02:13 PM | #32 | |
02-23-2007, 05:35 PM | #33 | |
Rock Crawler Join Date: Dec 2006 Location: Southern California
