Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Free WK servo mount templates
Old 05-01-2007, 09:56 PM   #121
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
How did you mount the plate to the pumpkin.
Harley is offline   Reply With Quote
Old 05-01-2007, 10:23 PM   #122
I mounted it to the tab that use to be used for the steering link then drilled another hole in that tab toward the back and then to the knuckle screw...if that makes sense. It is the tab off of the upper link mount...it seems very stable.
clarkrw3 is offline   Reply With Quote
Old 05-01-2007, 10:42 PM   #123
20K Club
Harley's Avatar
Makes plenty of sense. Good Idea.
Old 05-04-2007, 09:18 PM   #124
Well I finally got everything fully assembled and it works great. Couldn't have done it without that template!
4x4dodge is offline   Reply With Quote
Old 05-04-2007, 11:47 PM   #125
20K Club
Harley's Avatar
^^^BEEEEFY!!
Looks good man. Glad it worked out for ya.
Old 05-07-2007, 11:19 AM   #126
20K Club
Harley's Avatar
The BTA version now has an updated template available.
I do not have my axles here at the office so somone will need to cut it out and check to make sure all the holes line up properly.
Again, DO NOT PM ME, my box fills up so fast I can't stand it.
Send me an e-mail at jdthiede@transystems.com
Old 05-07-2007, 11:21 AM   #127
20K Club
Harley's Avatar
Old 05-07-2007, 11:23 AM   #128
20K Club
Harley's Avatar
AHHHHH NO PM's ABOUT THIS PLEASE!!!!!!!!!
Read two posts previous! Send me an e-mail!
Josh
Old 05-08-2007, 09:14 PM   #129
Default thanks for the pattern
Hey Harley, i just wanted to say thanks for the pdf!!! I didnt follow the pattern so much other than around the pumpkin...I went with a bent method then mounted the servo with servo mounts...there is so much strength and even more clearance from hitting the stock chassis!!!
thanx tho!!
nonstopboost is offline   Reply With Quote
Old 05-08-2007, 09:56 PM   #130
20K Club
Harley's Avatar
Looks good. Just like everything else in this niche of our hobby, everything is always able to be customized
Thanks for the props
Josh
Old 05-10-2007, 08:15 AM   #131
06 Super National Champ
JasonInAugusta's Avatar
Harley, don't know why I didn't think about this sooner, email me the .pdf files and I'll host them.
JasonInAugusta is offline   Reply With Quote
Old 05-10-2007, 08:27 AM   #132
Here they are for anyone that wants them:
Notice that the file "WK Plans" is three pages.
http://www.projecttwin.com/files/WKtemplates/
Old 05-10-2007, 08:35 AM   #133
20K Club
Harley's Avatar
Smile
Thanks JIA this should help clean out my mailbox now.
Thanks for all the intrest people!
I know other people have offered to host them before, but I am to the point now where it is hard to keep up with everyone.
Also, ALL of the templates are in that file: Servo mount, BTA servo mount, Clocked Motor plate.
Old 05-10-2007, 09:31 PM   #134
Wow....my first sticky. Well actually it's your sticky Harley0706 with no help from me, but whatever. By the way your mount is working GREAT!!
Old 05-15-2007, 08:42 AM   #135
Thanks harley for the template.
It worked great and saved me tons of time.
I would post a pic but I am at work and have very restricted access to the internet. somehow I can get this sight though. thank god!
just wanted to say thanks.
Mac10 is offline   Reply With Quote
Old 05-16-2007, 04:14 PM   #136
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Just made me a pair of these last night and have some clearance issues. Did anyone else have clearance problems at full turn with the "passenger" side knuckle arm coming in contact with the "third leg" of the mount where it screws to the axle C? Mine hits this third leg way before the steering reaches full throw. I will try and get some pics up tonight when I get home just in case I'm not explaining it well enough.
Offroader5 is offline   Reply With Quote
Old 05-17-2007, 11:29 AM   #137
20K Club
Harley's Avatar
Hey thanks a bunch! I appreciate the thought.
Post up a pic. I have a water jet cut version coming to me right now. We are running the same wheels so it should be similar. Otherwise.............get the dremel out!
Old 05-18-2007, 06:54 AM   #138
Thumbs up
Thanks a bunch for the kick a$$ templates! Im doing the BTA right now and making final adjustments. I am using 1/4" lexan instead of Aluminum. (friend had it, was free) so I will see how it holds out. Great templates, thanks again!
jason3114 is offline   Reply With Quote
Old 05-18-2007, 06:59 AM   #139
20K Club
Harley's Avatar
Make sure to check the template with the axle before you start cutting too much. The BTA one really hasn't been used yet.
Good luck and post some pics when you get it done.
Old 05-18-2007, 08:56 AM   #140
Offroader5's Avatar
Still didn't get any pics, but I ended up just cutting the third leg off and it's steering lock to lock now. I made the mount out of 1/8" 6061 AL so I am pretty sure it'll hold up well without that additional mount leg. I get pics up tonight (if I remember )
i believe the biggest reason why it was a clearance issue is because I have the tie rod mounted over the knuckle which made the whole rod end assembly on that passenger side a bit tall. I will end up having a drag link that is backwards also...it will go from the servo on the passenger side down to the drivers side knuckle.
