Thread: Quick question about WK shocks...
Old 03-14-2007, 03:02 PM   #1
Default Quick question about WK shocks...
Wheely King shocks look like they have ball-ends at either end, is that correct?
Mad Scientist is offline   Reply With Quote
Old 03-14-2007, 03:30 PM   #2
JIA's Dad's Avatar
The top cap of the shock has a ball type swivel built into it.
JIA's Dad is offline   Reply With Quote
Old 03-15-2007, 11:21 AM   #3
yes at both ends...
HauntFreaks.com is offline   Reply With Quote
Old 03-15-2007, 02:41 PM   #4
HPI's balls (the ones on the shock ends) have a little different shape to them then most.... more extending out from each side of the ball, and a large flat on one side. They work well, only problem is dirt/grime wears the plastic ball semi fast, where a metal ball in the plastic end holds up better.
Edit: the WK balls don't have the large flat, but they do extend out each side more then some... I was thinking of Savage ball ends.
swhenrik is offline   Reply With Quote
