Thread: 55t 65t or 75t?
Old 03-23-2007, 01:45 PM   #1
Default 55t 65t or 75t?
Which Motor will crawl better in a stock (just 4wd modified) WK the 55 , 65 or 75.. ? Could you noticed a huge difference between 55 to 65?
JeeperoManiako is offline   Reply With Quote
Old 03-23-2007, 02:09 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I would use a 55 or 45, maybe even a 35t in that thing. It has a really big geardown in the tranny, so you can get away with a lower turn motor on 6 cells.
JohnRobHolmes is online now   Reply With Quote
Old 03-23-2007, 03:15 PM   #3
Tech Addict
frdtrkguy's Avatar
I am using the 65t and I think i am going to switch to the 45t for more wheel speed. Good luck
frdtrkguy is offline   Reply With Quote
Old 03-23-2007, 04:00 PM   #4
NIDRCRC.com
I put a 55T in mine and it has plenty of wheel speed. Running 18/93 gearing.
themerc64 is offline   Reply With Quote
Old 03-23-2007, 04:21 PM   #5
id actually suggest a 35t, it will have enough torque and more wheel speed than w/ a 55t or 65t.
clod booster is offline   Reply With Quote
Old 03-25-2007, 04:48 PM   #6
Gavyn is my BFFL
Nabil's Avatar
i would say a 35t as well, should still let you bash or crawl
Nabil is online now   Reply With Quote
