| | #1 |
| Newbie Join Date: Feb 2007 Location: riverbank
| has anybody posted a how to on locking wheely king diff's ? |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| ask the search button JB weld Last edited by JIA's Dad; 04-01-2007 at 02:06 AM. |
| | #3 |
| RCC Addict ![]() Join Date: Sep 2005 Location: Tempe, AZ
| JB weld them!! |
| | #4 |
| Newbie Join Date: Nov 2005 Location: La Porte
| I've jb welded a stampede trans, but in case you want to open the diff back up, is there a way that is easily reversed? |
| | #5 |
| RCC Addict Join Date: Jun 2006 Location: Nor Cal
| Hot Glue |
| | #6 |
| NIDRCRC.com ![]() Join Date: Jul 2005 Location: Rathdrum, ID USA
| Fill this void with, JB Weld, Hot Glue, Plastic Weld, etc... |
| | #7 |
| cool thanx guys. was also thinking that it could be done with out jb weld, kinda like the tlt diffs with the extra gear in the diff case. i dunno |
| | #8 |
| Newbie Join Date: Apr 2007 Location: Bozeman
| can you show me where you put the jb-weld like a pic of it after you put it in there.thanks |
| | #9 |
| Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
| Ummm, it says fill this void with JB... That's how you do it, take apart your diff til you see this piece, clean all the grease out from around the gears, put the gears back in, fill 'er up....make sure you hold one of the axle shafts in the bottom or it might leak out. |
| | #10 |
| Rock Stacker Join Date: Mar 2007 Location: San Antonio
| | #11 |
| RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
| | #12 |
| Predator micro motors ![]() Join Date: Dec 2005 Location: houston
| If you use JB weld then fill the void all the way, then put the side gear back in while it's still wet. Now put it all back together before it dries. |
| | #13 |
| is the side gear the one on the top right of the pic? |
| | #14 |
| Rock Crawler Join Date: May 2007 Location: Franklin ME
| poster putty is working great for me. |
| | #15 |
| yea but i want no slip and have no clue where to get it |
| | #16 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| The crawler store is releasing their diff lockers soon. Drop in and done. |
| | #17 |
| Pebble Pounder Join Date: Apr 2007 Location: San Antonio
| Poster putty can be found at office supply places, Dollar General and probably Walmart and Target. With poster putty there is less chance of twisting off an inner axle and less stress when the car is turning, but it's so viscous (it's actually a non Newtonian fluid) that it does a good job of getting traction to the ground on both sides. I used some grease along with the poster putty and so far, so good. If you really want the diff "locked" then use some hot glue because you might be able to reverse the process. If you use JB Weld or epoxy then the diff will probably be locked permanently. If you use JB or epoxy, grease up the ends of the axles and make sure they fit into the diff capsule after you button it up and are waiting for the JB to set. If it sets and you can't get the axles in because the side gear is in a bit crooked or because the axle slots are filled with JB then you have a problem. |
| | #18 |
| Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
| I used JB Weld. I can't see any reason why I would want to switch back to an open diff, as my truck will never be used for high speed running. I can see where hot glue could be removed, but I think I would be more likely to go buy new parts than try to clean every last little bit of glue from between all those gear teeth. |
| | #19 |
| I used hot glue the first time I locked my diffs, it lasted a while but it did tear up and deteriorate...I took the diff apart again and through JB in there, haven't had a problem since. In other words, hot glue isn't permanent and will probably give out when you need that locker the most. JB it. |
| Thread Tools | |
| Display Modes | |
