| | #1 |
| Rock Stacker Join Date: Feb 2007 Location: Portland
| Today I was looking at WK parts on tower and found that they are selling the axles individually, for about 12$. I need axles for a scale build, and with the TLT disco'd I need some axles. But alas, I have a low budget. There is no way I can possibily spend 200$ for axles + hardware. So I was wondering, after the axle housings, what parts would i need in addition to the parts listed in the thread on making it a 4x4? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Feb 2007 Location: riverbank
| hpi part numbers 1 A549 axle stubbs 1 86813 drive shafts 1 A855 final drive gear set 1 A850 bevel gear set 1 A431 diff case 1 86810 gear shaft 1 Z242 2mm E clip come in pack of 20 use only one per axle/unless u use shk mounts 1 6819 o ring come in pack of 5, 2 o ring used per axle 8 5x11x4mm ball bearing 2 10x15x4mm ball bearing should be enough for one complete axle. besides the o ring& eclip |
| | #3 | |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| | #4 | |
| | #5 |
| WK tranny has been good so far. I have not tore into mine yet as I have not had any problems. I will say that in some strains/binds the tranny makes a clicking noise. It seem there is a slipper of some sort built into the tranny. Which for me has been good. I have not torn out ring and pinions like I've seen done on many TLT's. I have seen to much of them becoming 2 wd in comps to own one. YET, Well I guess I do own 2 but nether have been put together as I still have 2 TLT-1 kits in the boxes. NOT for sale!!!!! |
| | #6 |
| Pebble Pounder Join Date: Jan 2007 Location: Isanti, MN
| i would love to own a wheely king but i cant afford it. and with a tlt it depends on what tranny you use compared to a wk tranny. with a xxx-t tranny you can leave the slipper just a hair loose, and it will squeal like a pig right before you break something so you have warning. a wheely king will be my next rig though. that will happen once i get a job. i currently earn money by doing most of the upkeeping of the house and yard work because my parents both work. |
| | #7 |
| Quarry Creeper Join Date: Mar 2007 Location: Syracuse
| I think the 4x4 deal at Tower is the best bet for anyone. |
| | #8 |
| Newbie Join Date: Mar 2007 Location: Gainesville
| | #9 |
| the wk is not the best deal for me because it would be way more wasteful than buying a tlt kit. i have a radio, mamba max esc, and a xxx-t tranny. the servo and motor would not meet my needs, and i would only really use the axles and maybe the shocks. plus, i don't have the ablilty to fabricate a chassis and i dont know enough about link geometry and placement to mount wk axles to a chassis made for a tlt. like i said, "once i get a job the wheely king may be a good option." i think that hpi should make a wheely king kit because most of it would be wasteful excess of parts i would not need and i would be spending alot more money for alot of stuff i have no use for. a kit would at least spare the cost of rtr electronics. i love the wheely king, but it just isn't the most cost effective option for me right now without a job. and yes, i am looking for one. |
| | #10 |
| Quarry Creeper Join Date: Apr 2006 Location: the creek
| I think if you were to build one axle just from parts you would be looking at $70... so maybe $140 total... I could be high/low, but I think it is around there. |
| | #11 |
| I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| I came up with $163 and change including bearings from tower you might be able to get bearings cheaper from Tammies but even then you'll only be saving $5 bucks or so, for a 185 rtr its a much better deal |
| | #12 |
| heres a pic, I dont think I missed anything |
| | #13 |
| I wanna be Dave Join Date: Jan 2006 Location: CA
| Cheaper to buy the 4x4 WK and use the parts. Sell or trade what you don't need. I bought the 4x2 and it took several days and some digging to get all my parts for the conversion...spent too much on the parts too...got spares...lol. |
| | #14 |
| well, the 4x4 one is $210 normally, so ya, $180 or so if you can catch some of the deals they have... I can't see any reason not to buy the rtr... other than I am poor! |
| | #15 |
| Newbie Join Date: Mar 2007 Location: Bay Area
| i had the same problem waiting for the axles, so i just took out the back axles, measured them for a template, went to home depot , bought the same size solid rod and just grind it the same pattern. For the dog bone part, i had left over pins from other cars. Slide it in the hub to see if it fits. Then just drill a hole center of rod. total cost 2$ for two axles. |
| Thread Tools | |
| Display Modes | |
