Thread: nitro rs4 mt cvd's?
Old 04-07-2007, 11:32 PM   #1
Default nitro rs4 mt cvd's?
so I was looking through tower today, and of course who knows when mid april will be here, i looked through the stuff that came with my WK unfinished project in a box, and all i am missing from 4wd is shafts, bearings, and diff case. of course diff cases and shafts are mid april arrival. I can't justify spending $190 at the LDHS to get another 2wd for parts, so I got to looking. the dogbones for rs4mt are 83mm. the WK shafts are 82. How much longer would the dogbone be with it's drive cup? or how much longer would the cvd's be?
You should be able to get a couple of mm out of the C hub mounts with new screw holes. Would the cvd's be stronger? I know they tend to be on the mini trucks, but on the minis they are replacing plastic and alluminum with steel.
Didn't know if it would be worth it, considering there still are no diff cases. I may just throw this thing together 2wd just to play until parts arrive.
and even then, i don't want to backorder the diff case because it is a $5 part with a minimum of 3pc order.
hairba11 is online now   Reply With Quote
Old 04-07-2007, 11:50 PM   #2
Wont work since the Mt CVDs have a dogbone end. You would have to cut that off and machine them to have the same shape as the WK ones
Gula is offline   Reply With Quote
Old 04-08-2007, 12:11 AM   #3
the CVD will be to long.... but you could do this...
swhenrik posted this pic in his CXT build...
I pretty much did this same thing.... just remember this will only work in the rear these axles will not allow the knuckles to steer...
here are my pics.... Few ?'s before I buy a WK
HauntFreaks.com is offline   Reply With Quote
Old 04-08-2007, 04:23 PM   #4
wat did u make them axels out of
gravelcrawler is offline   Reply With Quote
Old 04-08-2007, 08:04 PM   #5
I used 1/4" steel round stock from lowes and .078 music wire for the pins
its all explained in this thread >> Few ?'s before I buy a WK
Old 04-08-2007, 08:43 PM   #6
i had considered something like that, maybe even taking them to the lathe at work and turning a ball for 4WS, but there still are no diff cases to attach thm to till mid april, and tower has a minimum preorder of 3 cases. I only need one and don't want to order 3 of tham @ $5 each to get one
Old 04-08-2007, 08:54 PM   #7
I had an MT parts car laying around so I used one of the diff's from that... but like hairba11 said, unless you machine a ball end on the stock it will only work in the rear because it will not steer...
Old 04-08-2007, 10:01 PM   #8
heres a shot of the MT, DIY axles and WK axle cups combo....
Old 04-09-2007, 12:05 AM   #9
Default Replacement shafts for WK with rs4 diff
Hey guys I think I found a replacement part for the DIY shafts when useing a rs4 diff with the drive cups. The replacement shaffts come in a pair for under 9 bucks, they are made by duratrax part number dtxc9662 for the maximum bx. check it out
http://www2.towerhobbies.com/cgi-bin...?&I=LXTP77&P=M
Milotronics is offline   Reply With Quote
Old 04-09-2007, 06:11 PM   #10
If someone does try to do anything with CVD's, keep in mind the front and rear CVD's on the NMT are completely different from each other, one wheel bearing is huge on the fronts. The WK uses the same style bearings and hub as the NMT REAR.
The NMT CVD shaft with the dogbone will be WAY too long with the NMT drive cups installed on the diff. A RS4 3 on-road MIGHT be closer, but someone would have to measure. Cutting the shaft and rejoining it should work, but then you won't be able to run the bearing at the outside of the housing, (which keeps crud out of the housing) similar problem Hauntfreaks and I have with our custom shafts.
The next option is cutting the dogbone end off, and grinding the flats on the shaft to engage the spider gears. But if the shaft diameter isn't large enough, you are S.O.L. I tried this with the NMT dogbones, and the diameter is definitely too small. The CVD's MIGHT be bigger, but you'd have to buy one and check..... hopefully someone will do just that!
swhenrik is offline   Reply With Quote
Old 04-09-2007, 07:37 PM   #11
Or try a super nitro CVD that might work if the RS$ one is too short
Old 04-10-2007, 01:18 AM   #12
I managed to get a pair of old Tmax CVD's to work, had to chop up a pair of Tmax hubs and make adapter plates.
lonewolf039 is offline   Reply With Quote
Old 04-10-2007, 07:44 AM   #13
Nice fab Wolf great idea with the maxx hubs.... I like the link mount also, any close ups??
Old 04-10-2007, 04:41 PM   #14
mid april is so far away. im gonna have to try something
Old 04-10-2007, 07:13 PM   #15
I have to slap myself to keep from driving an hour away to get another 2wd just to get an axle.
I'm gonna blow enough on the next tower order regardless..
Old 04-10-2007, 08:58 PM   #16
More pics over at Hustler style full droop Wheelie King
