Thread: how well does a stock 4x4 crawl?
Old 04-08-2007, 08:23 PM   #1
Default how well does a stock 4x4 crawl?
I have been looking at the wheely king for a few months now and i would like a opinion on how the 4x4 crawls. is it a resonable trail rig that could be driven on small rocks and tree roots?
please respond!!!!!!!
scorpion_king is offline   Reply With Quote
Old 04-08-2007, 08:26 PM   #2
I'm a stupid C U N T!
slobin3d's Avatar
out of the box 4wd it is very top heavy and with the battery in the back it doesn't do verticals at all, but with some simple mods its a pretty capable truck
slobin3d is offline   Reply With Quote
Old 04-09-2007, 12:28 PM   #3
It isn't horrible with stock 4WD but you should at least lock the rear diff. Even when the front diff is still open it doesn't crawl great. Decent.
NickRummy is offline   Reply With Quote
Old 04-09-2007, 02:28 PM   #4
06 Super National Champ
JasonInAugusta's Avatar
Top heavy, needs diffs locked, a lower turn motor, battery relocated, lower suspsension link brace removed...
There are a few builds here with guys using the stock chassis to build crawlers...it's a great foundation.
JasonInAugusta is offline   Reply With Quote
Old 04-09-2007, 02:55 PM   #5
as a trail truck it's good, but lock the diffs, reposition the batery, and remove the front brace, and your good!
SnailMail is offline   Reply With Quote
Old 04-09-2007, 06:08 PM   #6
Yes, but as a trail rig it works well with a little rearrangement it will crawl fairly well in near stock configuration. Locking the diffs and lowering the CG makes a huge difference.
Natedog is online now   Reply With Quote
Old 04-09-2007, 07:41 PM   #7
is it more of a trail rig or a crawler?
Old 04-09-2007, 07:52 PM   #8
It will work as either one, but if you're going to use the stock chasis, it's probly a better trail rig than crawler. If you want to build a tuber or something, then you've got crawler material.
cotharyus is offline   Reply With Quote
Old 04-11-2007, 01:47 PM   #9
what i want to do is to lock the diffs and move the batterie otherwise i want to keep it stock because im a kid. i dont have muck $$$.
Old 04-11-2007, 05:21 PM   #10
You don't need much money. Just a little creativity. I've probly got $25 or $30 tied up in the stuff I used to make my links, and I only replaced the stock shocks because I let my 4yr old son drive it and he broke one of them.
Old 04-11-2007, 06:45 PM   #11
i am getting a crawler together and i do not have alot of money. you just have to save a bit. a wheely king is a bit expensive for my situation because i am building a torision tlt off of the chassis EtypeR used on his turtle crawler (which competed quite well). my rig will cost a little under $200, but i already have a xxx-t i can get a tranny from, a radio, esc, and battery. the torsion chassis was free because it is just 4 metal plates and L-channel aluminum. but for your situation a wheely king may be a good option. just figure out how to reposition the battery to up in the front, lock the diffs with JB weld, and extend the wheelbase. i have heard of some people using threaded rod that you can find at most hardware stores, and so the threads don't grind on the rocks you just slide the plastic tubes from pens over the threaded rod links. threaded rod is pretty cheap, and then you just need some ballcups. i do not know how to extend the upper link because the info i know is for 4-link setups. maybe someone on here can instruct you on how to make an extended upper link. remember that saving takes a bit of time and patients. see if you can do yardwork for neighbors or other chores. i am sure you can find a way to make more money.
theTman is offline   Reply With Quote
Old 04-11-2007, 07:31 PM   #12
I got my battery over the front end by swaping the axles from end to end.
just hooked the drive shaft to the other side of the tranny, and reversed the motor wires so fwd on the esc still moved the truck forward. I made a servo mount plate for the front axle and used a turnbuckle to attach the servo horn to the stock tie rod. the servo wire to the radio was a stretch, but it helped the 2wd out a lot.
hairba11 is online now   Reply With Quote
Old 04-11-2007, 07:51 PM   #13
could you zip tie a flat 6 pack to the front of the chasiss?
Old 04-11-2007, 08:07 PM   #14
you might want to move the radio if you are going on top, but you might be better off trying to strap it underneath the chassis above the toplink
Old 04-11-2007, 08:12 PM   #15
but wouldn't that limit suspenion travl
Old 04-11-2007, 09:14 PM   #16
Worse than that, it would likely interfere with the steering linkage if you don't mount the servo on the front axle. I feel like for a number of reasons, relocating the servo is going to be one of the most important things you can do to make a mostly stock WK into a good trail truck or crawler. Now ask me why I haven't done it yet.
Old 04-12-2007, 04:27 PM   #17
if i streached it would it have more of a lower center of gravidy(with the battery in the stock place?
Old 01-27-2008, 10:59 AM   #18
if i stretched it would it have more of a lower center of gravity(with the battery in the stock place?
battery in stock place all it does is wheelie. heres how i mounted my battery. worked great, didn't interfere with my flex at all either.
phase10 is offline   Reply With Quote
Old 01-27-2008, 11:31 AM   #19
crawl abilities ... CRAP
small rocks and tree rots ... fun
overall really fun truck
andres-tavares is offline   Reply With Quote
Old 01-27-2008, 11:37 AM   #20
it'll kill a stock clod in a comp!
RockCrawlingKid is offline   Reply With Quote
