Thread: battery location
Old 04-09-2007, 12:04 AM   #1
Default battery location
does anybody have a good batt location to even out the weight?
hdcustomizer is offline   Reply With Quote
Old 04-09-2007, 04:41 AM   #2
Default Even weight
If using a six cell pack attach three cells on top of front upper links and do the same in the rear.
DIRT HAWG is offline   Reply With Quote
Old 04-09-2007, 10:09 AM   #3
Or stand up the steering servo (slightly to one side) and put all six cells on the front upper link(s) and the axle.
Old 04-09-2007, 07:43 PM   #4
Or you can flip the truck so that the front is in the back and vise versa. Flip the servo arm to the other side so that it feeds the back instead of the front. And switch the buttons on the remote.
camaro67 is offline   Reply With Quote
Old 04-09-2007, 07:45 PM   #5
Honestly? I'm using the stock battery box, but I've got it lowered. Just undo the screws that hold the back of the box, and drop it down until the top holes are lined up with where the screws went through for the bottom before. It doesn't get any of the weight forward, but it does get it lower. Of course, if you want to balance it, you can't beat the advice you're getting to put three cells each o the top links.
cotharyus is offline   Reply With Quote
Old 04-09-2007, 07:49 PM   #6
zip tie it to the front of the chasiss.
scorpion_king is offline   Reply With Quote
Old 04-09-2007, 08:02 PM   #7
all good ideas thanx guys
