04-19-2007, 05:05 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
| 2wd wk to 4wd is it possible??
i found a wk on ebay a 2wd one i want to crawl with mine is it possible to change the 2wd to a 4wd w/o killing my wallet??
04-19-2007, 05:22 PM | #2 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
| Pretty sure you'd need these parts: These are prices from Tower: 6819 O-Ring P-3 (5pcs) 1 $1.45 New 85258 Universal Drive Set 1 $12.99 86094 Screw Shaft M4x2x12mm (6pcs) 1 $1.90 New 86810 Gear Shaft 5x6x29mm (1pcs) 1 $7.69 New 86813 Drive Shaft 6x82mm (2pcs) 1 $12.99 A431 Diff Case Set 1 $4.79 A850 DIFF BEVEL GEAR P1x13T / P1x10T Set 1 $4.79 A855 DIFF BEVEL GEAR P1x38T / P1x13T Set 1 $5.79 B022 Ball Bearing 5x11x4mm (2pcs) 2 $12.99x2 !!! Yup just checked rcboyz....5 x 11 x 4mm PolyAmide Sealed Bearing $.99 each...... 5 x 11 x 4mm Blue Rubber Sealed Bearing $1.19.... 5 x 11 x 4mm Metal Shielded Bearing $0.99 B030 Ball Bearing 10x15x4mm (2pcs) 1 $13.99...Can be had for the same prices above^^^^ Mods/RCC vendors: If you sell these parts feel free to remove or add to the Tower P/N's. |
04-19-2007, 06:13 PM | #3 |
Newbie Join Date: Mar 2007 Location: Washington, DC
possible and also impossible. Due to high demand of converting 2WD to 4WD, you will hardly find all of these parts in any stores.
04-19-2007, 06:36 PM | #4 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
its cheeper to buy the already 4wd one |
04-19-2007, 07:51 PM | #5 |
Pebble Pounder Join Date: Apr 2007 Location: Nowhere
yea it cost almost 15$$ more to convert to 4wd it cheeper to buy a 4wd
04-20-2007, 07:02 AM | #6 |
well when the wheely king is going for $50 i thhnk its worth it
04-20-2007, 09:26 AM | #7 |
Rock Stacker Join Date: Mar 2007 Location: Redmond
| But it is doubtful that the auction will end at $50. For $193 shipped from tower for a 4x4, it just isn't worth it to buy a 2WD with 4x4 aspirations. And unless you find a super deal on a good used complete axle, you can pretty much forget trying to find parts for the conversion. And unfortunately, I have seen the axles alone get up to $102.50 on Ebay (For 1 axle!).
04-20-2007, 10:20 AM | #8 |
04-20-2007, 10:28 AM | #9 |
Rock Stacker Join Date: Mar 2007 Location: San Antonio
$220 shipped for a 4WD http://cgi.ebay.com/HPI-WHEELY-KING-...QQcmdZViewItem |
04-20-2007, 10:38 AM | #10 |
04-20-2007, 04:06 PM | #11 |
Or with towers discount, the 4X4 is under $200 shipped with ground shipping.
04-20-2007, 05:19 PM | #12 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Why shop EBay when you can buy from a known retailer for cheaper? Tower has them for $210 with a $25 discount, then you pay shipping. Ultimate has them for $190 with free shipping on orders over $100. Total either way is under $200. |
