Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Trail King
Old 04-21-2007, 01:57 PM   #1
Default Trail King
Few modifications -
Flipped servo so now the front is the back and the back the front. Battery tray up front. Extended wheel base. Replaced body. Integy lathe motor.
Two wheel version for now. Waiting on four wheel drive parts for about a month now while the 4WD version sits on the shelf at the hobby store. SAD.
bbyrd22 is offline   Reply With Quote
Old 04-21-2007, 02:11 PM   #2
Nice truck, im doing the exact same thing. Did you just hook up the motor in reverse to make it go backwards?
Also, whats you wheelbase, and what links did you use?
4x4dodge is offline   Reply With Quote
Old 04-21-2007, 02:24 PM   #3
Yes, I wired the motor in reverse.
Wheelbase is 12 1/4" wheel nut to wheel nut.
The links are some ESP links I pulled off an old clodzilla chassis. Hole to hole, the links are approx. 5 3/4".
Thanks.
Old 04-21-2007, 03:40 PM   #4
Thanks for the info
