05-15-2007, 02:14 PM | #1 |
Pebble Pounder Join Date: Apr 2007 Location: Auburn
| 4wd wk Wheel base longer what links do u use to make the 4wd wk wheel base longer.ALSO what shafts do you use |
05-15-2007, 03:24 PM | #2 |
Rock Stacker Join Date: Mar 2007 Location: San Antonio
I used emaxx shafts and outputs. Stock 2.5 Revo pushrods for upper links Tmaxx 3.3 turnbuckles (128mm) for lower I'm at |
05-15-2007, 09:10 PM | #3 |
ok i like it alot looks like your at 12"inch wheel base do u have more pics like a side view or ur wk.and is there a big difference when the tranny is unlocked or locked.
05-15-2007, 09:44 PM | #4 |
I wanna be Dave Join Date: Sep 2004
i don't think the wk tranny has a diff. do you mean the axles ?
05-15-2007, 09:51 PM | #5 |
i guess so idk what they have lol im new to this
05-15-2007, 11:45 PM | #6 |
Pebble Pounder Join Date: Apr 2007 Location: San Antonio
A Stampede tranny has a diff because it is made to drive the rear wheels on the pede, that is it's two output shafts don't go to the front and rear axles, instead they go to each of the rear wheels. The Wheely King tranny is made for a 4 wheel drive car, it's output shafts are made to go to a front and rear axles...so the WK tranny does not have a diff, both front and rear output shafts are locked together. You don't have to worry about locking a WK tranny. WK axles do have diffs. I drove my 4x4 WK for a week before putting poster-putty in the diffs. Poster putty is the adhesive putty made for attaching posters to walls without harming the wall. PP is much firmer than Silly Putty and PP fits into the WK's diff capsule very well, giving a limited slip effect. Limited slip diffs work very well for climbing and crawling but have some slip to help turning and to help prevent the axles from breaking. I drove my stock 9.5" wheelbase WK today and another guy drove his WK that has a 12.5" wheelbase and has the battery mounted on the front top links. His WK climbed much better than mine. My battery is mounted in the stock battery box but the chassis is reversed so the battery is now in the front. Problem is that the battery box places the battery high in the chassis. His battery that is mounted on the front suspension links gives his WK a much lower center of gravity. The lower CG lets his WK climb steeper rocks than mine can and his longer WB gives his WK lots of articulation and generally helps it crawl better. Hope this helps. The amount of info available can be pretty intimidating and the info is scattered here and there so it's hard to find. Hang in there and read, read, read. One question is worth hours of reading though. |
05-15-2007, 11:54 PM | #7 |
Quarry Creeper Join Date: Mar 2007 Location: AZ
I used arrow shafts to extend the wheel base. I am really happy with the way they turned out and how strong they are. I used revo rod ends on the shafts. For the drive shafts I used E-Maxx drive shafts and shortened them a little. |
05-16-2007, 12:05 AM | #8 | |
05-16-2007, 12:08 AM | #9 | |
http://smg.photobucket.com/albums/v3...Nitro/Crawler/ | |
05-16-2007, 10:13 AM | #10 |
ok thankyou MikeSSS that helped me out and thnakyou for telling me all that.HEY 1RCbasher2NV thanks for the photobucket and stuff nice crawler also do u have any vids of the stock 4wd wk
05-16-2007, 11:13 AM | #11 |
No stock vid,Sorry!!
05-16-2007, 03:37 PM | #12 |
ok n/p ill just have to wait and see wat it can do b/c im getting mine soon thats y im asking to see how to mod the wheel base
05-19-2007, 10:48 PM | #13 |
Newbie Join Date: Apr 2007 Location: Richmond
| Are these the parts?
I'm new to the Wheely King and RC Crawling. I'm wanting to extend the wheel base also. Are these the parts I need? I have to order them on line so I want to make sure before a placed the order: http://www2.towerhobbies.com/cgi-bin...3&I=LXDDY3&P=K http://www2.towerhobbies.com/cgi-bin...I=TRAC6319&P=K http://www2.towerhobbies.com/cgi-bin...3&I=LXSP55&P=K http://www2.towerhobbies.com/cgi-bin...I=TAMC6121&P=K If this is not right can someone please post the correct links? Thanks! |
05-22-2007, 11:43 PM | #14 |
hello ppl i used all the stock stuff on the wk and just put T-Maxx turnbuckles for the lower links and now i have a 10.5 wheel base.really all i need now is some shafts not sure wat to use.But i do have alot of pede shafts idk if they will work though.
05-23-2007, 12:03 AM | #15 |
Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
These are what I used for the shafts... http://www2.towerhobbies.com/cgi-bin...3&I=LXSP55&P=K Made my own links so I can't really help you there, kind of a hit and miss type thing when you first start out... |
05-23-2007, 01:13 PM | #16 | |
post number 2 in this thread tells you what to use ..... | |
