Thread: wheely king front diff zippers?
Old 05-26-2007, 11:18 PM   #1
Default wheely king front diff zippers?
got my 4wd kit for the wheely king works GREAT moved the battery and such.. but even with sil-glide on it "one of the best and smoothest silicone greases you can use for metal to metal contact" it still sounds like a zipper.. doesnt seem to be taking any damage just sounds funny at speed...
anyone else experienced this.. it was assembled as per direction sheet included and all that so lemme know
turbored21 is offline   Reply With Quote
Old 05-27-2007, 12:28 AM   #2
I just used wheel bearing grease, the gears don't make any noise at all. I also used it in the tranny, now my wk is almost silent except for the beeping of the esc.
4x4dodge is offline   Reply With Quote
Old 05-27-2007, 12:45 AM   #3
Mine is pretty quiet but has picked up a ticking sound.
MikeSSS is offline   Reply With Quote
Old 05-27-2007, 01:02 AM   #4
Mine has a fairly fast high pitched ticking noise, it is coming from my 55T Integy motor, But it seems fine so I just ignore it.
Old 05-27-2007, 08:16 AM   #5
Sense we are on the issue of noise. I just put a 35t in mine, and noticed that is a very loud motor. Is this normal?
skullking is offline   Reply With Quote
Old 05-27-2007, 08:26 AM   #6
My 55T lathe motor is silent except for a slight clicking noise. It is way quieter than the stock motor. Maby as the turns go down they get louder?
Old 05-27-2007, 11:12 AM   #7
ya idk its not damaging the gears at all.. and i only use silicone grease in these kind of applications because its so wear resistant maybe they just need a day or 2 of good runnin to break in and seat to eachother.. ill post if it gets better worse
Old 05-27-2007, 04:43 PM   #8
x2
but only forwards, in reverse it is quiet
is it just me? or does revese on the stock esc seem flaky?
hairba11 is offline   Reply With Quote
