Thread: crawler gear ?
Old 05-28-2007, 11:47 PM   #1
Default crawler gear ?
Im looking to get a very low crawl ration with my tuber. What pinion and spur gear with suit me the best for stictly crawling. Should i upgrade to a 55T motor or 65T, with what gearing.
noRCal is offline   Reply With Quote
Old 05-29-2007, 12:05 AM   #2
For just crawling use a 55t lathe motor geared 15/96. If you want a lower gear ratio then you will need to mod the motor mount.
4x4dodge is offline   Reply With Quote
