Thread: 1/6 scale with wheelie king axles?
Old 05-29-2007, 12:56 PM   #1
Default 1/6 scale with wheelie king axles?
I want to make an scale rc with wheelie king axles out of this.
http://img.epinions.com/images/opti/...Avalanche1.jpgClick the image to open in full size.
Auto-xer73 is offline   Reply With Quote
Old 05-29-2007, 02:10 PM   #2
so do it
cammok5 is offline   Reply With Quote
Old 05-29-2007, 02:48 PM   #3
Im asking if you all think it will work well. I want to use every thing stock and just lengthen it. I don't want to spend a lot.
Old 05-29-2007, 04:15 PM   #4
1/6 scorp.
Wheely King Axle Breakdown pics
Kranberry is offline   Reply With Quote
Old 05-29-2007, 05:48 PM   #5
They kind of seem a bit narrow. But I could get different wheels that make it stick out more.
Old 05-29-2007, 05:49 PM   #6
yea iam also sure some one has made a set of wideners for the wk liker they did for the tlt
Old 05-29-2007, 06:18 PM   #7
1RCbasher2NV runs 12mm to 14mm x 3/4" long adapters on his WK and uses Maxx rims with Maxx Mashers. The rims don't have much offset so width is not increased by mush but there are probably rims with more offset.
These big Mashers aren't much higher either but they are wider and are soft and sticky. He gets traction!
MikeSSS is offline   Reply With Quote
Old 05-29-2007, 09:38 PM   #8
dirk379's Avatar
Where did you find that for sale? I have been scouting those out for a while and cant seem to come across one?
dirk379 is online now   Reply With Quote
Old 05-30-2007, 12:07 AM   #9
CPE - Crawford Performance Engineering.
$35 a set of 4.
http://www.crawfordperformanceengine...A5&log_pid=yes
got a set on my 1st wk
check out the vendor section for cpe.
TONKA TOY is offline   Reply With Quote
