| | #1 |
| Quarry Creeper Join Date: May 2007 Location: Leander, Tx
| What is the max wheelbase you can have and still use a stock revo driveshaft? Has anyone sleeved a driveshaft to allow for alonger wheelbase. thanks. i get my wk in friday and i am starting to plan out a build. I'm new to crawlers but not to rc. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
| if you can get enough drive shafts so you can extend it you could make it 100+' long of you want,but its realy not nesesery for it to be 100' |
| | #3 |
| i'm not gonna be in any comps with it so wheelbase length is basically going to be determined by how far i can go before its too far. I am looking at around a 14" wheelbase. (What i am guestimating will be somewhere in the vicinity of what i want) I will know more once i get it here. Now on to driveshafts. I am sure i can sleeve it to make it as long as i need but i want to maintain driveshaft integrity. ( I snapped tmaxx shafts like they were made of wax when i was running the OS .18tm) I plan on using either revo pushrods or savage tie rods for my links. (lunsford with LST2 shock ends) |
| | #4 |
| Quarry Creeper Join Date: Feb 2005 Location: Vancouver Island B.C.
| You will probably end up shortening the revo shafts if you want a 14" WB. |
| | #5 |
| RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
| I have a 14.5 inch WB right now, I am using regular long maxx shafts the rear only has about 1/2" of overlap at full extension, but the WK slipper lets go before the shaft does. |
| | #6 |
| Power of the Portals ![]() Join Date: Feb 2004 Location: where ever the wind fawkin blows me, tx
| if you use revo shafts, you will be shorting them. But pretty bullet proof. Check out my sig. |
| | #7 |
| awesome. looks like i am going with revo pushrods as lowers and savage turnbuckles as uppers to i can tweak my pinion angle. thanks i'll let you know the final config tommorow |
| | #8 |
| ok so this is what i need. uppers http://www2.towerhobbies.com/cgi-bin...&I=LXDDY3&P=ML lowers http://www2.towerhobbies.com/cgi-bin...?&I=LXHFW0&P=7 what revo shafts do i need? And are these the only parts i need to extend the wheelbase? |
| | #9 |
| I am gonna wait until i decide what kind of chassis to use. I don't want to buy links and whatnot to extend the stock chassis and then have to redo it when i go with a new chassis. any suggestions? |
| | #10 |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| Bender SW2 or 3 |
| | #11 |
| so those will work even though they say its for a tlt? I saw where a guy used mugen shock towers and it looked great. I have some nova shock towers from a savage but if a bender will work then i'll scoop that up instead. |
| | #12 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| I wouldn't worry about what how long you can get with those shafts untill you decide 2.2 or max size. If you go 2.2 I wouldn't go longer the 12.5 range, unless you use All-T's then maybe 14 would be ok. Just cut the shafts and run something in that range. |
| | #13 |
| thats what i was thinking. i placed a few orders today. picked up the following to get me started. Traxxas driveshafts 12 feet of dubro 4-40 all thread 4 allthread couplers dubro HD rod ends 96t spur pushrod spacers robinson racing pinion 6 pack (15t-25t) integy 45t lathe motor gonna try to use an rc18b shock as a steering link/servo saver I have some nova shock towers for a savage that i am going to use as a possible chassis. As well as a few other parts from the savage. i have a 200oz metal geared airtronics steering servo and some other stuff |
| Thread Tools | |
| Display Modes | |
