Thread: Do the stock wheely king have foams?
Old 06-02-2007, 09:14 PM   #1
Default Do the stock wheely king have foams?
Because i was cleaning my tires and rims ( i dont know why i was just bored) and i got water inside my tires and i cant take all of it out of the holes and my truck wobbles very bad...
GUERO4X4 is offline   Reply With Quote
Old 06-02-2007, 09:21 PM   #2
nope, no foams.
kurt is offline   Reply With Quote
Old 06-02-2007, 09:35 PM   #3
If you need to clean your tires use a fingernail brush with some warm soapy water. Dip the brush and scrub the tires, don't submerge the tire/wheel combo or they'll get alot of water in there...as you now know.
Old 06-02-2007, 10:02 PM   #4
yea i always clean my tires with a old toothbrush but this time i got lazy
Old 06-02-2007, 10:07 PM   #5
MWRCA'er
Mnster's Avatar
Suck it out with a straw.
Mnster is offline   Reply With Quote
Old 06-02-2007, 10:26 PM   #6
Are you serious? naw im not that retarded
Old 06-02-2007, 11:59 PM   #7
Just be sure to use a small straw, like the one off of a WD-40 can, you can clean it out before you use it by spraying the WD-40 through it.. :-P ..
joemomma95 is offline   Reply With Quote
Old 06-03-2007, 11:10 AM   #8
I had the same thing happen to me after driving around in a brook.I used a small flat screwdriver and pryed a small section of the rear of the tire off the wheel and used the screwdriver to pull the tire away from the wheel while holding it upsidedown.All the water came running out down my arm so do it over a sink or something.Dry the wheel and tire and reglue that small section.I put an air valve in my wheel's and sealed the vent holes.Now i can pump up the tires for mud/water and best of all i can remove air and make the tire wrap around a rock like a glove,best traction i ever had,and no water in the wheels
ridgewalker is offline   Reply With Quote
