| | #1 |
| Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
| Does Anyone Know If You Can Narrow The Stock Rims On The Wk Like You Do With The Pede Rims. |
| Sponsored Links | |
| | #2 |
| Just having Fun Again ![]() Join Date: Apr 2006 Location: In your fridge stealing a beer
| I don't we why not. From what I can tell from the rim you can do the front but not the back. |
| | #3 |
| thanks red rockcrawler i hope i meet you at the comp coming up |
| | #4 |
| We already met and crawled together. |
| | #5 |
| Pebble Pounder Join Date: Jun 2006 Location: under my truck
| i have done the back on my stock wk wheels but think thats one reason mine stick out so far |
| | #6 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| You can narrow most any plastic wheel but some are harder than others. Trick on the hard ones is boil the beads in hot water after you cut them off. When the plastic gets hot it expands. While the beads are hot you can stretch them on the same diameter wheel. As the beads cool they tighten on the wheel. Then plastic weld on. I have done several sets. But have also gotten blisters on my fingers from the hot rings/ beads once. Be careful!!!! |
| | #7 |
| Quarry Creeper Join Date: Apr 2007 Location: marysville, washington
| hey, if you have a drill press and an air die grinder, then you can mount the bit w/ a cutting wheel in the drill press and use the drill press bench to lower, raise or trim w/ perfect lines everytime. |
| | #8 |
| Newbie Join Date: May 2007 Location: Elkins
| I have narrowed mine and am running full width mashers. these things crawl great and i have no complaints! |
| | #9 |
| Hey thanks every one for all of your advice. I reall appreciate it. |
| Thread Tools | |
| Display Modes | |
