Thread: kreepys' dig tranny in action!!
Old 06-04-2007, 12:20 AM   #1
Default kreepys' dig tranny in action!!
check out the video on this link...http://www.youtube.com/watch?v=83xobuFBrA0
kreepykrawler is offline   Reply With Quote
Old 06-04-2007, 12:27 AM   #2
Keep it real
Tanis's Avatar
What, no brake? That's cool, freewheel helps in some situations, but being able to lock up the rear axle will give you the most benefit, and a tighter turning radius. I like how smooth yours works.
Tanis is offline   Reply With Quote
Old 06-04-2007, 12:31 AM   #3
Just having Fun Again
Red Rockcrawler's Avatar
Nice kreepy crawler I can't wait to see this in yakima.
Red Rockcrawler is offline   Reply With Quote
Old 06-04-2007, 02:30 AM   #4
thanks guys. my wife thinks i spend WAY too much time in my workshop messin' w/ this. hmmff, what does she know?
Old 06-04-2007, 08:53 AM   #5
That is really cool!!! It should help out a bunch, for those sticky situations!!!
minifaron is offline   Reply With Quote
Old 06-04-2007, 08:57 AM   #6
no worky.
RockRacer1 is offline   Reply With Quote
Old 06-04-2007, 11:02 AM   #7
rokracer, wtf does that mean it works, definately.
Old 06-04-2007, 11:06 AM   #8
Originally Posted by RockRacer1 View Post
no worky.
copy and paste the link
kurt is offline   Reply With Quote
Old 06-04-2007, 11:29 AM   #9
Power of the Portals
here the link for the *I'm to lazy to copy and paste the link people....*
eric113 is offline   Reply With Quote
Old 06-04-2007, 02:10 PM   #10
that is a sweet setup. i though about doing that to a scaler but puttin the dig on the front so you could lock the 4wd in and out. have you herd of anyone doing that?
tjarr001 is offline   Reply With Quote
Old 06-04-2007, 04:49 PM   #11
1 man, 2 sons
Unimoger's Avatar
where is the " dig tranny " ? all I see is a servo moving the driveline from 4wd to 2wd, no brake, no tranny mod at all. How does that set-up work under full articulation? looks like it may fail.
Unimoger is offline   Reply With Quote
Old 06-05-2007, 12:12 AM   #12
I crawled that crack
hotwheels000's Avatar
Been running mine all last season with no brake:-( ...I guess it didnt work:-P
hotwheels000 is offline   Reply With Quote
Old 06-05-2007, 11:54 AM   #13
tjarr, i like the idea of the front locker, how 'bout front and rear? THAT would be cool!!!!
Old 06-05-2007, 12:29 PM   #14
Talking
Unimoger,
Thanks for the Ericksons, they are unbeliveably fantastic! Could you elaborate a bit more on what a "dig tranny" is from your point of view. The "dig" concept is new to my world (just the past month or so) and I'm still trying to wrap my head around it. I've seen kreepy's in person, and it does tighten up the turning radius and allow all sorts of cool maneuvers on the rocks that I cannot do with my "undug" rear end. But I don't know anything about brakes or tranny mods? Any info would be most helpful before I set off and start building. Also, having seen this truck in action, it does work at full articulation. Thanks - Da Chimp
SpyderMonkee is offline   Reply With Quote
Old 06-05-2007, 04:24 PM   #15
yeah unimoger, could you elaborate or provide a pic or two to clarify for us unknowing? i could see how a brake would add a definate advantage. i have to say though, that even set up like it is there is a huge difference in the turn radius as well as the ability to pivot the truck around by hooking a rock w/ either rear wheel or to slide the front end around or over on a pretty steep climb. i'm LIKIN' it, but i wanna LOVE it!
it does not come out/in at full stuff, the collar seems to be right in the middle and its acting sort of as a pivot or hinge for the "dig" to have full free movement and articulation is very good. i've had to limit it in fact quite a bit w/ some fuel tubing.
Old 06-05-2007, 04:35 PM   #16
I think part of what Unimoger is point out is there is no adjustment at the tranny (like a 2 speed would do). Yes, it is a dig (with no brake) but it isn't exactly accurate to call it a tranny dig.
I do like how it pops in and out fairly smooth. The one time I tried that, it wasn't nearly as smooth. Are the splines ground down at a 45 degree angle?
Cloak is offline   Reply With Quote
Old 06-05-2007, 04:37 PM   #17
Web Wheeling
Etype R's Avatar
A dig tranny would be like the R2 with rear disconnect, the dig system is part of the tranny.
Your setup is just a dig setup, it has nothing to do with the tranny as all it does is disconnect the rear drive shaft, and its completely separate from the tranny. Also its not a true dig if you are not locking the rear axle as well.
Etype R is offline   Reply With Quote
Old 06-05-2007, 04:53 PM   #18
o.k. that makes a lttle more sense. yes the shafts are at a 45. i ground them and then used a jewelers file to clean up each of the splines so that it goes in and out smooth-style.
i'll check out the r-2 closer and see what thats about.
Old 06-05-2007, 05:02 PM   #19
Web Wheeling
Etype R's Avatar
Its still in the prototype stages, I am waiting for the latest version which I might see late this week, or next week.
Old 06-07-2007, 12:15 AM   #20
Keep it real
Tanis's Avatar
Ya, ya, but that was soooo last season Donovan just put dig on his, he has freewheel and lockup. Very , might have to put dig on Britt's, but I don't want her to beat everybody that bad.
Looking forward to crawling with you again Kreepy, keep up the fabbing
