| | #1 |
| Newbie Join Date: Feb 2007 Location: Somerdale
| Has anyone had any problems with the stock shocks on the king? I went to lhs and bought a set for another crawler of mine and the cap on the oilfill end keeps cocking and leaking if its really flexing. Thank you all in advance. |
| Sponsored Links | |
| | #2 |
| ΜΟΛΩΝ ΛΑΒΕ ![]() Join Date: Dec 2006 Location: Gonzales,La
| yea mine did that also put some teflon tape on it that may work |
| | #3 |
| I thought the same thing but I'd rather see if there is anything else that I can try to be 1 hundred percent sure of the fix. |
| | #4 |
| no sure on that |
| | #5 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| The stock ones are not much good after they start popping off. You can run a screw through them if you really need to use them. Otherwise I would just go with a nicer quality shock. If you want to have a quality dependable crawler that is the best choice. |
| | #6 |
| Is there another shock out there that is the same size as the stock shock? |
| Thread Tools | |
| Display Modes | |
