Thread: rear pinion clicking?
Old 06-10-2007, 04:59 PM   #1
Default rear pinion clicking?
who here has had there pinion click and grawl at you? i was at a comp to day and it starded doing that
Kranberry is offline   Reply With Quote
Old 06-10-2007, 07:22 PM   #2
JIA's Dad's Avatar
Could be the slipper clutch in the tranny. If it was under a bind!!!!
JIA's Dad is offline   Reply With Quote
Old 06-10-2007, 07:46 PM   #3
the drive shaft was spinning but no wheels spin to the wheels
Old 06-10-2007, 09:43 PM   #4
On mine, HPI shimmed the ring gear away from the pinion. Flip the shims and your golden.
Terminator13 is offline   Reply With Quote
Old 06-11-2007, 12:09 PM   #5
open your diff
re-assemble the ring gear part don;t forget to use locktite on the 3 little screws that hold it together
shim the pinion and shim the ring gear
re-assemble diff repeat with front diff
go compete
same thing ahppened to me
good luck
chivas72 is offline   Reply With Quote
Old 06-11-2007, 12:35 PM   #6
Mine'll do that too.
BJoe is offline   Reply With Quote
Old 06-11-2007, 12:43 PM   #7
well i opened it up an every thng stripped nicley :-( so i geuss a new diff and hardend steel pinion.hopley that will to the trick
Old 06-11-2007, 01:06 PM   #8
well don;t forget to shim the new ones
rcp has the parts you need in stock
Old 06-11-2007, 01:29 PM   #9
thanks chivas for the help but i am gonna check my lhs be fore ordering onlinei cant find it on there site could you link it to me?
Old 06-11-2007, 03:46 PM   #10
http://www2.towerhobbies.com/cgi-bin...?&I=LXJJ88&P=7
Old 06-11-2007, 06:39 PM   #11
ok ill get those tomorow
Old 06-11-2007, 07:51 PM   #12
I'm getting one this week so I want to know a lttile about this. How old are the trucks that do that, was it a 4wd and what all would I need to do to make it stop doing that. I heard a few guys say just move the shims, is that all you do? BTW I'm a noob to crawling.
Nasher is offline   Reply With Quote
Old 06-11-2007, 09:25 PM   #13
Well mines a 4wd, but I opened the diff up right away after hearing it. I recomend doing this before running the truck. All you do is take the shims farthest away from the ring gear and swap em to the other side so it shims the ring gear closer to the pinion.
Old 06-19-2007, 08:38 PM   #14
Can someone tell me in this picture where things go? I assume the red and blue shims go where the red ones are currently? Or do they go where the green arrow is? I don't know the correct terminoligy(sp?) on the ring gears and pinion gears, not sure which is which...
joemomma95 is offline   Reply With Quote
Old 06-19-2007, 08:53 PM   #15
Doont mess with the internals. Take the bearings off the diff and you'll see the shims.
Old 06-19-2007, 09:05 PM   #16
Ok terminator, so in this picture take the shims out from underneath the bearing with the red arrow and move them to under the bearing with the blue arrow?? Thanks for the quick response ..
Old 06-19-2007, 10:32 PM   #17
you got it
nigels_world is offline   Reply With Quote
