| | #1 |
| Pebble Pounder Join Date: Jun 2007 Location: Red Bluff ,California
| I just finished getting my WK done. Im running Moabs on some Stampede wheels. The wheels arent narrowed . I was having a problem with the stock WK wheel hexes not seating far enough into the Pede wheels because of the raised section on the hexes. so I shaved them off for a better fit. But now the wheels rub on the Knuckles. What can I do to fix this?? Is there a better set of hexes? Or am I overlooking something? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2005 Location: Yuma,AZ
| did you get front or rear pede wheels. |
| | #3 |
| They are the rears |
| | #4 |
| should have got the fronts that is probably your probably.you might be able to narrow them some more.somebody w/ more knowledge can probably help |
| | #5 |
| Newbie Join Date: May 2007 Location: Van City
| lost of dremel work will make them fit without rubbing. the inside of the inner lip needs to be sanded down and also the ends of the steering links. |
| | #6 |
| Rock Crawler Join Date: May 2007 Location: Franklin ME
| narrow your wheels |
| | #7 |
| RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
| | #8 |
| Thanks for the info guys. I went and did some careful clearancing with my dremel and added a 3mm shim. Problem fixed. But I think I will need to something better. So in the future so I wont have to do this to every wheel and tire combo I try. |
| | #9 |
| Pebble Pounder Join Date: Nov 2005 Location: Raleigh
| my pede wheels didn't work either, you can either cut the lip off the hex, or switch hexes to get them to work.... |
| | #10 |
| Rock Stacker Join Date: Jun 2007 Location: Virginia Beach
| | #11 |
| Quarry Creeper Join Date: Feb 2007 Location: Fresno
| Why not just buy a set of wideners? I used the Junfac wideners on my TLT with the stock WK tires and wheels, and on the otherwise stock WK my sister got for her B-day. No problems, and should work with any 12mm hex wheel you want to run. Here's a link: http://www.tcscrawlers.com/product.p...3&cat=0&page=1 |
| | #12 | |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
Double-narrow some pede rears and you'll be fine. I like RPM Revolver rears. Wheely King Axle Breakdown pics | |
| | #13 |
| Yeah, but when you are already 471 miles wide, whats another inch? Besides, with Pede rears and "normal" 2.2 tires, is it realy that much wider than it is with the huge stock tires? I took so long with my TLT build they went and discontinued it on me, and now the WK and AX-10 make my axle choice seem kind of... regretable. |
| Thread Tools | |
| Display Modes | |
