| | #1 |
| Newbie Join Date: Sep 2006 Location: south jersey
| mine only last about 10 mins, maybe i didn't let it fully charge? i think i let it charge for about 4-5 hrs, guess thats not enough for the first time? also, when its starts dieing, it moves in reverse but not forward, how about everyone else? maybe i set something up wrong? thanks, Matt |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jun 2007 Location: Weatherford
| Mine dont last long either. I went to a GP3300 and it lasts for more than an hour maybe even longer. I havent had a chance to run it to the drop yet. |
| | #3 |
| once it dies how long does it take to recharge? thats stock battery that is, im goin to get a new one sometime this week, also how long does the GP3300 take to charge? thanks, Matt |
| | #4 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| Did you read the book that came with it? It usually tells what charge time is. |
| | #5 |
| yeah i think it said 5 or 6 i just put it on the charger now, (8 o clock) how long do you think i should let it charge? i didn't read anywere how long you should after the first time |
| | #6 |
| Newbie Join Date: Jul 2007 Location: Portland
| I found my book to my WK useful some what but in other areas not really. My stock battery runs dead in about 12 minutes so i'd say 10 is normal. I bought a 3800mAH battery from local hobbytown usa. |
| | #7 |
| Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
| | #8 |
| Rock Stacker Join Date: Feb 2007 Location: Ottawa, Canada
| it usually takes 2 or 3 charge / drain cycles to get a battery up to speed ( no pun ) - you might find a noticeable difference after that. I dumped mine, got 2 high mAh battteries, and a quick charger - about 25 minutes charge, and I'm good to go... |
| | #9 |
| thanks guys, i just came in from buildin a course out back, pretty big once im done, about 25x12 maybe even bigger, not bad for the corner of my backyard |
| | #10 |
| Newbie Join Date: Jul 2007 Location: Camp Pendleton
| The stock charger output is 300mah an hour. With the stock battery rated at 1500mah, it will take approximately 5 hours to charge to full. I only get about 15 mins with the stock battery. I just bought a venom 3600, with a new charger that outputs 1.8a or 1800mah an hour, giving me a charge time of 2 hours and hopefully a runtime of 1+ hour. |
| | #11 |
| | #12 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| I'm running a 45t with a 3000mAh and I get about an hour with a charge time of an hour with a peak charger |
| | #13 |
| Rock Stacker Join Date: Jun 2007 Location: Sacramento, CA
| You defiantly should upgrade your battery to at least a nimh 3000Mah or more. And get rid of that junk stock charger and get a good peak charger. Even just a cheaper one. You can get the perona for like 50 bucks and its a great charger. very customizable to suit your needs. |
| Thread Tools | |
| Display Modes | |
