Thread: stripped hole in link
Old 07-18-2007, 11:58 PM   #1
Default stripped hole in link
I was doin' the conversion to rock crawler with my WK and screwed the 4-40 in too deep on the upper link in front and stripped the hole. Now the 4-40 just slides right out! I was thinking just CA it but it's a high stress area. Drill through and lock nut on other side maybe? Dunno. Open to ideas. Thanks ya'll. New to RC and all.
solomon7 is offline   Reply With Quote
Old 07-19-2007, 12:17 AM   #2
How about get a new end link that probably cost a total of 55cents.
Shaun is offline   Reply With Quote
Old 07-19-2007, 12:18 AM   #3
MWRCA'er
Mnster's Avatar
3mm is slightly larger
Mnster is offline   Reply With Quote
Old 07-19-2007, 12:50 AM   #4
blakeski's Avatar
i use a tap and die set and make my links 8/32, works great
blakeski is offline   Reply With Quote
Old 07-19-2007, 02:16 AM   #5
it's not the lower link it's the upper v shaped link.
Old 07-19-2007, 08:18 AM   #6
JIA's Dad's Avatar
2' of 8-32 all-thread and 4 ball ends cost about $5. or $6. make it a 4 link.
JIA's Dad is offline   Reply With Quote
Old 07-19-2007, 09:23 AM   #7
konafreeride11's Avatar
id use superglue..
konafreeride11 is offline   Reply With Quote
Old 07-19-2007, 09:29 AM   #8
Losi Factory Pilot
Rubbaneck's Avatar
Put a small drop of super glue on a toothpick or sharp object. Then coat the sides of the stripped out hole from top to bottom. Let that dry and do another small coat. After it has dried, get your parts back together and thread in the screw. This will hold just fine with out spending a dime.
If this doesnt work, repete the steps until a desired hole is achieved.
Rubbaneck is offline   Reply With Quote
Old 07-19-2007, 02:11 PM   #9
Awesome, thanks ya'll. I think I got it in for now until I can do a 4 link. Still got alot to learn , thanks for all your help!Now all I gotta figure out is the darn click.
Old 07-19-2007, 02:25 PM   #10
Is you First name really Solomon? I thought I was the only one! Lol. But peronsally, I would do what JIA's dad said and just go 4 link on it. Thats what I am running after I decided to ditch the extended top link.
musicmaniac is offline   Reply With Quote
Old 07-19-2007, 05:06 PM   #11
Yup! What's even wierder is my wife's name is Sheba and she's from the same area. Spooky huh?
PS: any suggestions for parts for that 4 link?just don't know how to ditch the upper link or where to get the cool brackets I see in pics. lol
Old 07-19-2007, 05:31 PM   #12
Search <click
Kranberry is offline   Reply With Quote
Old 07-19-2007, 05:36 PM   #13
I don't quite understand the Sheba comment. the only Sheba I have ever heard of was one of Noah's grandchildren in the Bible.... But, as for the links... Lol... Use 8-32 all thread like JIA's dad said. You can pick it up at Lowes, home depot or pretty much any hardware store. Then go to your lhs and get some rod ends. As for the "cool brackets" those are the tamiya suspension stays for the TLT. They are becoming harder to find though. I personally just used a piece of u-channel aluminum. the search at the top of the page is a HUGE help sometimes.
Old 07-20-2007, 05:44 AM   #14
Wink
Gotcha . Thankks for the info musicmaniac and all! Time to Search!
re: Sheba ( or queen of ) read Kings and song of solomon
