Thread: droop suspensions?
Old 07-19-2007, 01:23 PM   #1
Default droop suspensions?
Ok so what is the advantage to a "droop" suspension? I guess that it would give you a lower center of gravity and all, but I am assuming that it is strictly for a crawler rig, right? It looks like most of the pics of droop rigs that I have seen dont have any other sort of suspension, could someone explain the advantages or disadvantages to using this type of suspension?
Thanks!
Jay
crawler_king is offline   Reply With Quote
Old 07-19-2007, 01:25 PM   #2
Droop Vs. others
you need to use the search feature.......took me less than a minute to find this!
phishead1101 is offline   Reply With Quote
Old 07-19-2007, 01:27 PM   #3
JIA's Dad's Avatar
I used the SEARCH button. Typed in Droop VS Sprung and found lots of info including this:
Droop Vs. others
JIA's Dad is offline   Reply With Quote
Old 07-19-2007, 01:28 PM   #4
Droop Vs. others
Beat you to it!
Old 07-19-2007, 01:29 PM   #5
JIA's Dad's Avatar
Phishead, you type faster than I do. Good find. HaHa
Old 07-19-2007, 01:40 PM   #6
Doh sorry guys, Been awhile since I have been on an open or new board that required the use of the search feature... sorry and thanks for pointing out the obvious to the oblivious....
Old 07-19-2007, 01:45 PM   #7
No worries! good luck with the WK
