Thread: Wk shock...
Old 07-21-2007, 10:49 PM   #1
Default Wk shock...
Okay I mangle one of the shock caps and I wanted to know if there were any aluminum shocks I could use for the stock setup? Also is there a place to buy servo mounts?
I think near plans are
install the 55t
knuckes since I broke one.
maybe front cvds if I have enough
I might buy some rock lizards to go on the axial beadlocks.
thats about besides moving and shifting weight around.
cembom is offline   Reply With Quote
Old 07-21-2007, 11:52 PM   #2
JIA's Dad's Avatar
Hot bodies shocks!!! and here is where to get the mounts:
http://www.rccrawler.com/forum/showthread.php?t=74210
JIA's Dad is offline   Reply With Quote
Old 07-22-2007, 12:04 AM   #3
I crawled all day with the Rock lizards at a comp today. They work well, I strongly suggest them.
Shaun is offline   Reply With Quote
Old 07-22-2007, 07:45 AM   #4
Thanks, does HB make a 5 inch shock? If so where can I find it I have only seen 4"s I think. I think I will order the mount today or tommorow.
Old 07-22-2007, 08:00 AM   #5
3 of my shocks busted... spilling oil onto the carpet... i just CA glued the caps back on with no oil.. and added springs from my tamiya dark impact... works good now...
guywithhat is offline   Reply With Quote
Old 07-22-2007, 02:05 PM   #6
The hot bodies are to short for the wk chassis you will lose articulation unless you get creative and set up new mounts, dont know if they make 5" hb's, hpi makes some good shocks for the mt, someone has a thread on here with them mounted, and integy mr5's for the maxx are 119mm according to tower hobby.
I just mounted rock lizards on beadlocks they hook up great I also recommend them.
yarddog35 is online now   Reply With Quote
Old 07-22-2007, 10:53 PM   #7
I think I saw some hpi shocks in aluminum. I think the wks are like 5 inches the maxxes are in around 4 and I think the savage shocks are longer than 5. Does anyone know the length of 5 inches in mm? I cant think of it right now to save my life.
Old 07-22-2007, 10:56 PM   #8
JIA's Dad's Avatar
25.4 mm = 1 inch x 5 = 127= 5 inches
Old 07-23-2007, 01:21 PM   #9
Thank you much. So no one makes axle cs yet? I was hoping that fatrock would or something. Like servo/ batt mount, axle ces, knuckls.
Old 07-26-2007, 05:26 PM   #10
Got my shocks in today. 5 inches and threaded :thumbsup: I will get pics up and stuff later. What do you have to do to get the King bling servo mounts to fit? Oh yeah stock axle.
