| | #1 |
| Newbie Join Date: Jul 2007 Location: Orwigsburg,PA
| i have a wheely king with 4wd drive and locked diffs. i noticed recently that when driving in reverse and when theres a lot of pressure on the front end the gears grind. i took apart both the front and rear axle to compare to see if the front axles gears were chewed up. they look fine. i think though that one of the 4 axle screw are stripped. can somebody please help this is my first crawler build and i have parts on the way |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jun 2007 Location: Weatherford
| Im new too and dont know, but try the search button. lots of good info on here. |
| | #3 |
| Newbie Join Date: Jun 2007 Location: Surrey, B.C
| im still learning too..just finished stretchin my King out..i would suggest trying a couple shims in the front diff..worked to get mine nice and quiet and tight. |
| | #4 |
| but im not using a servo mount template using those screws and only 1 of mine is stripped. do you really think that one screw is causing me this horrible grinding all of the sudden! |
| | #5 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| Shim the gears!!! NOOB |
| | #6 |
| Pebble Pounder Join Date: Jan 2006 Location: Brockville
| | #7 |
| i used a crawlers best friend to lock my diffs: JB WELD Last edited by wheely king; 07-23-2007 at 01:37 PM. |
| | #8 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| are you sure its the gears and not the wheel hex? Can you record the sound it makes and post it up for us? |
| | #9 |
| ILL CHECK |
| | #10 |
| Rock Crawler Join Date: Sep 2004 Location: Knoxville
| Noob's calling out other Noob's..........LOL priceless! |
| | #11 |
| Thread Tools | |
| Display Modes | |
