Thread: question
Old 07-24-2007, 04:49 AM   #1
Default question
what is the WK differential/axle ratio? iv used the search, found plenty of gear info on the tranny but nothing on the axle. i wanna find final gear ratio with some different spur and pinions to see what i want. thanks
grapegoat is offline   Reply With Quote
Old 07-24-2007, 07:09 AM   #2
I think it is a 13/38 or about 2.92
That is digging back in the brain a little tho.
hairba11 is offline   Reply With Quote
Old 07-24-2007, 08:48 AM   #3
JIA's Dad's Avatar
The answer to your question is found in the sticky at the top of the page on the WK axle. I found it by using the search button. Look at post # 37.
JIA's Dad is offline   Reply With Quote
Old 07-24-2007, 08:54 AM   #4
actually the answer is right above your post. i used the search button but i guess i didn't look hard enough. thanks for pointing out my noobness
