Thread: drillin
Old 07-25-2007, 03:40 PM   #1
Default drillin
any one know how drill holes in the output shafts on r2 tranny . i keep brakein drill bits and doin much
upoveryou is offline   Reply With Quote
Old 07-25-2007, 03:42 PM   #2
try putting some oil on the drill bit as you drill. My guess is that you are heating the bit up and it is binding and breaking the bit.
scrooloose is offline   Reply With Quote
Old 07-25-2007, 03:51 PM   #3
good drill bit or cheap one.... titanium or carbide bits for steel....
make sure you drill straight... use a drill press if you can... if you angle the bit while in the hole.. it will grab the side and break....
meh... hope this helps...
guywithhat is offline   Reply With Quote
Old 07-25-2007, 06:02 PM   #4
there was a post about this on hear not to long ago. about 4/5 people tried it and the all faild. you can get the driled shaft from rc4wd. i think like 10 bux
cammok5 is offline   Reply With Quote
Old 07-25-2007, 09:00 PM   #5
Im do alot of metal fabrication at work, so here are a couple tips to drilling steel. first, center punch your hole location on the shaft. Next, get a 3mm drill bit, as the fractional sizes arent close enough to work well. You dont need a fancy bit to drill these shafts, i use regular HSS bits. Next, get some cutting oil, i use rapid tap. Now, when you start drilling, DONT over speed the drill bit! You will burn off the cutting edge of the drill bit. Go slow, using moderate pressure. 90% of the people i have watched using a drill overspeed the bit every time. SLOW DOWN, faster speeds just work against you, and if you cant resharpen a drill bit(a whole other topic), you have to get another bit. These shafts are easy to drill, i have done 2 shafts so far and havent even sharpened the bit yet.
dittohead is offline   Reply With Quote
Old 07-25-2007, 09:16 PM   #6
I would like to do my tlt shafts. Would they be steel and same directions? I mean how hard are they compared to the others?
cembom is offline   Reply With Quote
Old 07-28-2007, 01:02 AM   #7
thanks guys i got the holes in it. i went slow with it worked good
