Thread: Question for those who are still using servos in hte stock location.
Old 07-28-2007, 03:50 PM   #1
Default Question for those who are still using servos in hte stock location.
Have you guys had problems with the pushrod going from the servo to the trans side bellcrank flexing into the spur gear when you go with a bigger gear and are in a place where the steering gets bound up? I've made a replacement for for that pushrod (I'll post carnage and solution pics later), but I'm just curious who else has had this happen.
BJoe is offline   Reply With Quote
Old 07-28-2007, 08:31 PM   #2
I didn't have any problems with clearance with a 96 tooth gear. It was a little tight, but still cleared.
Dick Furious is offline   Reply With Quote
Old 07-28-2007, 09:19 PM   #3
I didn't have clearence problems at first even when I turned the chassis around, then when I put M2K's with 1/2 1/10 scale buggy foams, 2.25oz of weight on the front wheels, 625mg servo, and a 1000mAh Rx Pack it started flexing the plastic upper pushrod into the gear. I've got pics loading onto Photobucket right now.
Old 07-28-2007, 09:44 PM   #4
Default OK, here's the pics!
After putting a better servo I noticed a noise like the spur gear was stripping but couldn't find the associated damage until I took a better look at the upper steering pushrod and discovered this
After I took this pic, I flipped the link and put it back on. A couple days later the screeching returned and I discovered this!
Click the image to open in full size.Click the image to open in full size.
Well, I got to looking at the parts wall and spotted some of the rod ends in this bag
The gears in the old noggin got to turning and I found some other things to do some fabbing
These rod ends seemed to be the right shape and take 4-40 all-thread nicely too!
After doing a little guesstimating I came up with this
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
And here's the final product next to the replaced parts
Now for the installed pics
Tested it after work and it's a big improvement, now I just need to reinforce the bellcrank/UCA mount on the front axle.........
