| | #1 |
| Rock Crawler Join Date: Jul 2007 Location: Rectalville
| Still don;t have my WK (should be here next week.) But I was wondering what's the better set-up, to just extend the stock 3-link top bar (or one of the integy aluminum ones) or to go to a true 4-link set-up? Which one gives more articulation, control, better handling, etc? thanks, Chris Peterson a.k.a JavelinSST390 |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
| 4 link |
| | #3 |
| Quarry Creeper Join Date: May 2007 Location: Tunin' Tires
| Set up properly, they are about equal. Having said that, it is easier to get a 4 link set up properly. |
| | #4 |
| Quarry Creeper Join Date: Jun 2007 Location: Sacramento
| I'm not so sure, I think a 3 link is easier to set up because you can set the pinion angle with only one link. Using the stock upper 3rd link and an extended peice of all thread, you can set the pinion anlge and not have to worry about getting two links the exact same length. just my 2 cents... |
| | #5 |
| Rock Crawler Join Date: Apr 2007 Location: LaSalle
| I would have to say the 3 link is way easier to setup. |
| | #6 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| do the 3 link first, then, if you dont like it, change over to 4 link my tuber is 3 link, springer is 4 link. I like em both |
| | #7 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| I originally set mine up as a 4 link, but after seeing how it flexed, I went back to a 3 link using the stock upper mount and made my own wishbone link for it. One good thing about using an upper wishbone is it makes for a good place to put a batt pack or some electronics...makes a nice flat shelf |
| | #8 |
| Pebble Pounder Join Date: Jan 2006 Location: Brockville
| and with the 3 link i've seen a few people using it as a mounting surface for batteries or servos or what have you..... |
| Thread Tools | |
| Display Modes | |
