| | #1 |
| Rock Crawler Join Date: Oct 2006 Location: kowlifornia
| I am finally building a chassis that is not of my own design. I recieved the EZ's design TM-4 chassis earlier this week and hope to make it a highly competitive comp machine. My driving on the other hand will dictate otherwise. 1) tm-4 chassis 2) locked ( possibly narrowed ) WK axles 3) modified WK trans. ( maybe a dig setup not sure ) 4) some Bling bead locks 5) either Mashers or some new tires like the Losi's or Axial Sticky label. 6) Mamba Max - or maybe the new Novak Crawler ESC. 7) low COG so far these are the things that I am shooting for here is a pic of the chassis |
| Sponsored Links | |
| | #2 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| Thats a good lookin chassis. What is the extra holes in the lower bottom of the back chassis plate for? |
| | #3 |
| Rock Crawler ![]() Join Date: Feb 2006 Location: Cutting Comms
| Those are to mount a pede tranny in the lay down position, just like an sw2. |
| | #4 |
| | #5 |
| Power of the Portals ![]() Join Date: Feb 2004 Location: where ever the wind fawkin blows me, tx
| Sweet looking chassis, One thing I would do is round the width of the 2 bottom edges that see the rocks. |
| | #6 |
| I might look at that once I get the links mounted. I think the links will actually hide whatever is hanging down, but I will make that determination once I have them mounted. I have an idea for some links that I have not seen yet. I should have some updates by Wed. or Thurs. Last edited by rockhugger; 07-31-2007 at 01:34 AM. |
| | #7 |
| RCC Addict Join Date: Sep 2006 Location: Redlands
| Awesome.. :-) |
| | #8 |
| 2) locked ( possibly narrowed ) WK axles Can you elaborate on how you plan to narrow the axles? Last edited by RivBlueNoma; 07-31-2007 at 02:02 PM. |
| | #9 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| Doesn't seem like it would terribly hard to do, but it does look like it would be hard to make LOOK good. |
| | #10 |
| well, I haven't updated this for a while because no real progress has been made. I have a few mock upi shots to see how these WK axles look under the chassis. Most parts just bolt up with little to no mods. |
| | #11 |
| so I came up with a quick slipper mod for the WK tranny that locks it completely. replacing the spring with a shock spacer that will hold the floating gear in place for constant engagement. here are some pics. |
| | #12 |
| Nifty. |
| | #13 |
| I finally had some time to work on this build recently and this is what I came up with. the two most talked about and design intensive parts on the WK. The two parts of the WK that can make it a competative crawler, or just a run of the mill WK is the steering servo mount, and the tranny plate / mount options. I finaly came up with a design that I like. Here is my steering servo / battery mount that I made for my Wheely King axle. also, pictures of an experimental lower center link mount which is centered just below the pinion and made from household WK parts. Last edited by rockhugger; 10-12-2007 at 08:40 AM. |
| | #14 |
| Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
| I'm with RivBlueNoma, lets hear more about this narrowing of the WK axles??... I did a search on this and having found anything.... I see in your pics of the under side of the rig this has been done... can you go into detail on how?? |
| | #15 | |
I will revisit the narrowed axle idea later so that I can run different wheels or maybe aftermarket bead locks. I didn't mean to dissapoint, but this build is way over due and I need to move away from the more time intensive stuff until it's at least running. I love the chassis, I think it's going to be really stable. here is another pic of the battery / servo mount form the top. Last edited by rockhugger; 10-12-2007 at 06:20 PM. | |
| | #16 | |
| I wanna be Dave Join Date: Jan 2006 Location: CA
Schweet, looking good. | |
| Thread Tools | |
| Display Modes | |
