Thread: Shock oil weight?
Old 07-30-2007, 12:35 AM   #1
Question Shock oil weight?
I was thinkin' bout sorta tryin' out no sprongs just shocks for more of a droop style to see if I like it. Would 100 sil shock oil be enough in stock WK shocks? would I nee to spring em inside to get a real droop or would that oil be enough to give me an idea of how a drooper would ride? Just tryin' to figure out which direction to take my WK. Thanks for any input ya'll. Hard to search, very very limited time on the computer.
solomon7 is offline   Reply With Quote
Old 07-30-2007, 12:58 AM   #2
In between.
SACCO's Avatar
I liked mine with 100 wt. I thought it needed to be a lil bit thicker and am running 3k diff oil now. Crawls good but if speed is needed it sucks arse. It wont react fast enough if I have to go fast and becomes unpredictable. This is CRAWLING so slow is the way to go, so I am gonna leave it in there for awhile.
good luck. Droopin is fun, but most of the 2.2 comp winners are still springers me thinks.
SACCO is offline   Reply With Quote
