| | #1 |
| Newbie Join Date: Jan 2007 Location: Vancouver, BC
| Dear RCCrawler.com, I would like to first introduce myself as a long-time lurker, creep, once-flamed to the point of destruction, third-time poster, with a newly-found obsession known as, well you're familiar, rc crawling. Long-windedness aside, what follows is the current state of my ghetto-knighted WK, His Droopyness. This truck has been ultra-entertaining from its stock form, providing me with a much needed escape from the sometimes stress-inducing real world. I searched this forum rigorously after reading several posts with advice from JIA's Dad, and have subsequently arrived at a setup that I believe is somewhat unique, and most definately capable. Stats: WB: 12 9/16 in (all numbers in inches) Track: 8 3/4 Overall Width: 9 3/4 Center Chassis Clearance: 2 and uhhhhh..... 1/2? Diff. Clearance: 1 3/4 Traxxas TX5 Integy 45t HPI 96t Spur Lost a new 15t pinion Outside-narrowed, inside-trimmed Stampede 2.2 Rear Wheels 2.2 Moab's w/ the ubiquitous star-cut standard foams 1/16th inch steel rear-attached servo mount w/ stock servo Zip-ties abound Stainless 18gague wire Plenty of 4/40 lock-nuts Pics: ![]() ![]() ![]() ![]() ![]() ![]() Relavent tech-related content: In the droop setup I'm currently running, I've installed stretched-out retractable-pen springs in the interior of the rear shocks, no springs in the front with Dremel polishing-wheel bumpstops, and Motocraft MTX-75 Automatic Transmission oil in all four shocks. I've entertained adding mechanical pencil springs (which are about a third the lenght of the above-mentioned springs) all around on the outside of the shocks for some extra cushioning, and smoother style. Has anyone else run a similar set-up, and how has it worked for you? Well with the relief that I've actually asked a technical question, I can only hope that the mods will allow this build-thread-of-sorts to propagate, as I'm eager to hear what fellow members have to say about this truck. Haam |
| Sponsored Links | |
| | #2 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| I like how utilitarian the wheels look. I ran some springs inside on my droop setup, but didnt get enough flex. I am running shorter shocks than you though with 3k diff fluid in front and 100wt in rear. |
| | #3 |
| Rock Crawler Join Date: Oct 2006 Location: Tacoma
| looks good but you should build a custom chassis and get some bigger tires. Hope you can ge tin to the mix of rcc without problems this time around. good luck...... _stallion |
| | #4 |
| Rock Crawler Join Date: Sep 2004 Location: Knoxville
| Looks good but whats unique about it? |
| | #5 |
| "I like how utilitarian the wheels look. I ran some springs inside on my droop setup, but didnt get enough flex. I am running shorter shocks than you though with 3k diff fluid in front and 100wt in rear." -- I'm not getting much flex either, though it does provide stability in the rear for climbs and such. "looks good but you should build a custom chassis and get some bigger tires. Hope you can ge tin to the mix of rcc without problems this time around. good luck...... _stallion" -- I'll eventually go the custom chassis route, most likely a replica of a contemporary 1:1 competition rock crawler or rock racer. As for the tire situation, what bigger, taller tires would you suggest? The only ones that have appealed to me are the 40series/2.2 hybrids, as nobody seems to make a sticky, tall 2.2, and I'm not quite ready to cut up brand-new meats. "Looks good but whats unique about it?" -- 'a setup that I believe is somewhat unique'.... I've put my own spin on several mods (front steering servo mount for example). Find me another stock chassis, arbitrarily stretched (12 9/16in * I'm new to forums, so if someone could explain how to quote multiple times in a post, do let me know so I might create a less cluttered reply. |
| | #6 |
| ** nevermind about the mulit-quote thing!! |
| | #7 |
| Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| How is that front servo mounted? Hard to see the back or bottom. |
| | #8 |
| | #9 |
| Newbie Join Date: May 2007 Location: Van City
| Rig looks good. Looks like you used the search button well. Might i just say that i think you need to upgrade the body to something nicer. And did you have to do and mods to the axles to get the peds to clear the knuckels? |
| | #10 | |
| Thread Tools | |
| Display Modes | |
