| | #1 |
| Newbie Join Date: Jul 2007 Location: spitsbergen
| my question is in the topic. pictures would be great |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Sep 2005 Location: ...Here & There
| Step one: Put your finger on the throttle lever/trigger Step two: Pull back on lever/push forward on trigger That's how you put your WK in reverse... |
| | #3 |
| Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
| Do I really need to take a picture I would do it the same way Raytard did it. |
| | #4 |
| Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
| You've got to be kidding If you need it looked over to make sure it reverses, I'd be more than happy to have my 9 year old test it for you |
| | #5 |
| I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| Reverse the wires going to the motor. If you do that though, don't come back asking how to make your WK go forward.... |
| | #6 |
| RCC Addict Join Date: May 2006 Location: China Grove, NC
| You could put the body on backwards. This modification requires the removal and instalation of body pins, so you may want to ask you lhs for help. |
| | #7 |
| Rock Stacker Join Date: Jun 2006 Location: Nortern Kentucky
| Guyes stop ripping on him, he means how does he turn the frame around so that it still goes the right way but the battery is up front. |
| | #8 |
| WildTrialFilms ![]() Join Date: May 2005 Location: the land of the midnight sun
| ^^X2^^ |
| | #9 |
| In between. ![]() Join Date: Jul 2006 Location: Moscow Mills MO
| remove the 2 screws holding the knuckles on each axle. Disconnect the steering linkage and the rear lockout bar from the axle. Now, swap em front to rear, rear to front. Next you will have to remove the servo from the box it is in and make a servo mount to put on the front axle. You have something at home that will work. Be creative. oh yeah, you also have to make a new steering drag link.......... |
| | #10 |
| Newbie Join Date: Jun 2007 Location: Sacramento
| Saccos got the idea. I just did mine but the cameras out of town. Don't forget to reverse the motor wires so your new wheely king drives forward. Just remember that the front and rear axles in your wheely king are idendical. So they will swap just fine. The hardest part will be moving the steering servo since it will now be in the back and the steering arm won't reach. Or maybe it will but you should still make the servo mount on the front axle because they steer soo much better this way. Just check out the sticky. BTW you don't have to do anything to the body mounts. |
| | #11 |
| Rock Crawler Join Date: Jan 2007 Location: Midway
| I'm sorry guys but he needed the ribbing. I agree with the other guys on this. I typed in under the search button (reversing the wheely king) and found this: Simple WK mods and results The search button is your friend!!!!!!!!!!!!! |
| | #12 |
| Pebble Pounder Join Date: Apr 2006 Location: Grand Rapids
| never fails jia's dad used the search button and finds it. maybe every one should try the search button. |
| | #13 |
| Quarry Creeper Join Date: Jul 2007 Location: Waiting on the world to change
| i lowed the body mount as far as they can go, don no how much this helps but penny saved penny earned er however that saying goes |
| | #14 |
| Um..... ok. |
| | #15 |
| f... u guys. but i got the answer on a norwegian forum and found out how to switch the axels my self, it was the steering that was the prob |
| | #16 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| Well then........... |
| | #17 | |
You gotta be the bigger man bro. The SEARCH button should always be your first tool. If you post up "f... u guys" we are surely gonna jump on you like a pack of wolves. Chill, delete this thread, and enjoy all the info this site has to offer. | |
| Thread Tools | |
| Display Modes | |
