Thread: Motor wires reversed neccassary?
Old 08-04-2007, 11:06 AM   #1
Default Motor wires reversed neccassary?
I was wondering if it is really neccassary to reverse the motor wires when you flip the wk chassis or axles? I've read all the builds (I think) but nobody says anything about just flipping the switch on the tx. I know its not a big deal to resolder wires,just curious if the motor operates better wired correctly.
kshoopman is offline   Reply With Quote
Old 08-04-2007, 11:15 AM   #2
06 Super National Champ
JasonInAugusta's Avatar
Reverse the wires.
I've been lazy and tried flipping the servo reversing switch, the truck (not a WK) would still run in the wrong direction.
Tried programming with the throttle channel reversed. It would work for a bit then lose programming.
Put the throttle channel back to normal, flipped the wires and all was well.
JasonInAugusta is offline   Reply With Quote
Old 08-04-2007, 11:24 AM   #3
Flip the wires. you can just hit the switch but in reverse the ESC sends less voltage yo your motor and in forward it will send more voltage to your motor.
Shaun is offline   Reply With Quote
Old 08-04-2007, 01:03 PM   #4
Thanks guys I figured there was a good reason for it.
Old 08-04-2007, 06:52 PM   #5
i've got a 45t in my wk and it seems like it's quicker in reverse than foward. could the wires be reversed?
smcurry83 is offline   Reply With Quote
Old 08-06-2007, 11:14 AM   #6
Could be timing of the motor.
Set the motor to 0 degrees timing.
