Thread: locking spider gear with jb weld
Old 09-29-2007, 08:01 PM   #1
Default locking spider gear with jb weld
will using jbweld to lock the spider gears in the diff work just and good as a locker or will the locker work better?
iceman320 is offline   Reply With Quote
Old 09-29-2007, 08:08 PM   #2
NIDRCRC.com
They will both work the same, but the jb weld works cheaper!
themerc64 is offline   Reply With Quote
Old 09-29-2007, 08:14 PM   #3
putty it up!
Dirty Jeepster is offline   Reply With Quote
Old 09-29-2007, 08:16 PM   #4
jb works, but is irreversible.
firesprink281 is offline   Reply With Quote
Old 09-29-2007, 08:50 PM   #5
Just put some hotglue in their?
xxizzer421xx is offline   Reply With Quote
Old 09-29-2007, 10:38 PM   #6
will the hot glue work the same as the jb weld?
Old 09-29-2007, 11:05 PM   #7
hot glue will temporarily lock it. and will have limited slip till it gets chewed up.
Kranberry is offline   Reply With Quote
Old 09-29-2007, 11:18 PM   #8
NIDRCRC.com
Hot glue works great as long as you dont leave any space for it to move or break up. Hot glue can be removed too! I have used nothing but hot glue in many different transmissions and differentials without any failures. Just be sure everything that is being glued is clean, dry and oil free then pack it in there tight. Do not leave any open areas. I just use hobby grade clear sticks, but the black ABS sticks work the best if you have the right gun for it.
Old 09-30-2007, 06:25 AM   #9
MSB
hot glue is awesome if you like to redo it every month or so..... i ended up jb welding mine, but if i knew what i know now and they were available i would buy the lockers and call it done
MSB is offline   Reply With Quote
Old 09-30-2007, 10:35 PM   #10
yeah I have been thinking about buying the lockers for the ax 10 and putting them in my wheely king axial says that they will work in the wheely king so I think that I will go that way.
Old 10-02-2007, 01:38 PM   #11
At Home Depot they sell an two part metal epoxy for ~$3. I used it in both front and rear axles. It is more the consistency of clay, instead of a thick liquid like JB Weld. All I did was make some 1/4" diameter balls and mash them into the pumkin around the spider gears. Then filled in any necessary spots. Then cleaned up where the axles will be. The one problem with the epoxy is, it is soft for only 5 minutes. After ~5 minutes it will be as hard as steel. It works great for me.
duleonar is offline   Reply With Quote
Old 10-02-2007, 02:53 PM   #12
Originally Posted by iceman320 View Post
lockers for the ax 10 and putting them in my wheely king axial says that they will work in the wheely king....
Yes they will. I'd just buy these or the ones that a couple other vendors sell and be done with it. I JB Welded mine when I built em becuase nothing else was available. JB Weld works great but takes longer.
Old 10-02-2007, 02:58 PM   #13
RCGuy lockers cant be beat.
SpyderMonkee is offline   Reply With Quote
Old 10-02-2007, 05:48 PM   #14
Ya but who really ever says- " You know, I think that being open diffed was so sweet compared to this getting traction bullsh!t...."
sickfab is offline   Reply With Quote
Old 10-03-2007, 06:56 AM   #15
Ditto on what Spydermonkee says:
"RCGuy lockers cant be beat."
Too simple - open up the diffs, drop in the lockers and forget about it!! As they say "No fuss, no muss"
Sean
SeanD is offline   Reply With Quote
Old 10-04-2007, 11:26 PM   #16
If you use hot glue or JB weld, get out as much of the empty space in there as you can by putting a little of the locking compound of your choice in first, then rotate the gears a bit to work it in, then complete filling the diff. I think the reason for failures is air gaps in the diff.
DarthRacer is offline   Reply With Quote
Old 10-05-2007, 07:31 PM   #17
good point on the air bubbles and movine the parts to work it in!
MinotCrawlerz is offline   Reply With Quote
Old 10-05-2007, 09:28 PM   #18
That's the ones that I was trying to remember! Great guy to deal with too.
