| | #1 |
| Quarry Creeper Join Date: Sep 2007 Location: Duchesne
| what have you guys been using for the links to make your wheely kings wheelbase a 12.5" wheelbase? thanks |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
| i got my links from insane rc he has them for just about any chassis and he can make custom links |
| | #3 |
| Quarry Creeper Join Date: Feb 2007 Location: Fresno
| I have been using 4-40 threaded rod, and 3/16x.035 aluminum tube to test out lengths and geometry. When I find a length that works I contact David over at www.xtremerchobbies.com and ask him to make a set of lower 3/8" Derlin links with HD Revo ends. I keep the 4-40/alloy tube upper links, but use his links on the lowers. They are just 3 shades of awesome in a 1 shade world. I couldn't be happier with them and will be ordering a few more sets soon. You can find him in the vendor section or PM insanerc. |
| | #4 |
| Newbie Join Date: Aug 2007 Location: Las Cruces
| I have been using carbon arrows and rod ends from made by Associated for their MGT (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFUG9). I just went to a local archery store and ask for "cutoffs" and they handed me several for free. To tie it all together I bought some 8-32 all thread from Lowes. Hope that helps. |
| | #5 |
| Quarry Creeper Join Date: Jun 2007 Location: Del mar
| Custom Derlin links 3/8 with Revo ends from insanerc. www.xtremerchobbies.com Last edited by Usmc8541; 10-13-2007 at 05:11 PM. |
| | #6 | |
| Crawling is a fad... ![]() Join Date: Aug 2007 Location: Toronto, Canada
Getting back to Iceman's comment.... my links were premade by the previous owner and well I will be creating my own links anyways... so I know I made them. I think the ones he made were 4-40 and 3/16th brake line. | |
| | #7 |
| Rock Crawler Join Date: Jul 2007 Location: Rectalville
| I made mine from Revo rod ends and some 6-32 allthread rod, with THREE layers of K&S Aluminum tubing over that. The smallest piece fits so tightly over the allthread that you have to thread it on, then the other two slip-fit tightly over that. I tried to bend one of the links I made by hand and couldn't do it. I've purposely abused them and haven't bent one yet. (I have, however, messed up three link/shock mounts. two of them are sloppy on the axle and the third one straight BROKE!) |
| | #8 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| On my 2.2: 5/16" solid black acetal (Delrin) with Jato rod ends. Jato's only cause that's all I had at the time...I would have used Revo's. On my super: 3/8" solid black acetal with Revo ends. Also, just to clear up Javelin's post above...he must be using Revo SHOCK ends and not the pushrod and toelink rod ends which are a bit larger. When using the larger toelink and pushrod one's (which is primarily the "Revo's" everyone is talking about when they say "Revo's")...you need at least 8-32 threaded into them. 6-32 is too small unless you are in fact using the Revo SHOCK ends. Last edited by Offroader5; 10-13-2007 at 05:11 PM. |
| | #9 |
| Pebble Pounder Join Date: Nov 2005 Location: Raleigh
| i used #8 threaded rod, with steel brake line, sleeved with pic bens and revo ends and i would be really really surprised if i ever bent one |
| | #10 |
| Pebble Pounder Join Date: Dec 2006 Location: Southern Arkansas
| I'm a big fan of the XRC bent links on my TLT based rig. They've taken plenty of abuse. |
| | #11 |
| Pebble Pounder Join Date: Jul 2007 Location: jonesboro
| i used traxxas end links, 4-40 all thread and steel 1/4 inch brake line. cost a total of $10.00. Ive beat the heck out of them and still nice and strong |
| | #12 |
| Rock Crawler Join Date: Apr 2007 Location: St. John's
| | #13 |
| Newbie Join Date: Mar 2007 Location: Depoe Bay
| Not to change the subject, but for those using bent links, how do you bend them? I am using m4 ss threaded rod with aluminum sleeves and traxxas revo rod ends, but am not sure on the best way to bend the rod and aluminum. |
| | #14 |
| okay thanks for the help guys I might use the spare revo turnbuckles that I have for my links. and the just use the e savage or t-maxx center drive shafts. |
| | #15 |
| well guys I put the revo turnbuckles on my wheely king for the links and they made the wheelbase of my wk the same as my t-maxx so I should be able to use the t-maxx center driveshafts right? |
| | #16 |
| All I did for shafts was get a bag of Traxxas half shafts PN4951 (HD Driveshaft E/Tmax .15) and use the male shafts with the HPI female. They slid right in and didn't bind, all I did was pop the HPI male end off the U-joint and pop the Traxxas one on, then cut it to length and tested it. I have 3 3000Mah packs through it with a 20T motor and haven't had any problems yet. |
| | #17 |
| Newbie Join Date: Oct 2007 Location: Chile
| | #18 | |
Actually, I screwed up. I DID use 8-32 for the links. The ones I used are the Revo Short Rod ends. I actually didn't realize my mistake on that until I went to convert mine to a four-link this weekend. Grabbed the 6-32, went to screw 'em together and went "DOH!" :-x Good catch, though. Last edited by JavelinSST390; 10-15-2007 at 10:07 AM. | |
| | #19 |
| ok guys i used some revo turnbuckles that I have lying around the house so those are going to be my links. And my diff lockers came in the mail today so I got them installed so my diffs are locked now. so now all I have to get are the center driveshafts. is there any way that I could make my center driveshafts metal instead of the t-maxx plastic ones? |
| | #20 |
| You could get some RC4WD punisher shafts, but they're expensive and I have no idea which size you would need. |
| Thread Tools | |
| Display Modes | |
