Thread: which hexes?
Old 10-14-2007, 01:23 AM   #1
Default which hexes?
aloha guys, i had a question. i stripped the hexes with my stock wheels, so i just ca glued them in place. now i'm about to buy some axial beadlocks and i need to know what hexes will work other than the stock ones. thanks in advance.
basher808 is offline   Reply With Quote
Old 10-14-2007, 02:39 AM   #2
The Real Dogman's Avatar
This should do it::
http://cgi.ebay.com/HOT-RACING-HPI-W...QQcmdZViewItem
The Real Dogman is offline   Reply With Quote
Old 10-14-2007, 07:09 AM   #3
Those hexes will likely work, but be aware that the Axial beadlocks will probly be he next thing to go.
cotharyus is offline   Reply With Quote
Old 10-14-2007, 12:50 PM   #4
My axial beadlocks had the hexes strip right away, now the locking screws are stripping, I think the screws are too small, and shoudl be 3mm.
If you can find a way, sepend the extra money to get a high end beadlock, sounds like Ericson's are the best you can buy, and how can you argue with a lifetime warranty. No other wheel maker comes close to that.
If those are too expensive, I recommend RPM wheels. I've NEVER been able to strip a hex in one, and they come with their own hexes that you can use. Downside is you gotta glue the tires, but everything is a tradeoff.
todd1803 is offline   Reply With Quote
Old 10-15-2007, 08:24 PM   #5
The nitro rs4 aluminum hexes from tower work perfectly and they are only $5 bucks.
curve is offline   Reply With Quote
Old 10-15-2007, 08:28 PM   #6
Yes, but always gotta keep wheel nuts tight and check them through out the day. I'm using stock hexes with the raised center portion cut off and then CA glued to the inside of my Traxxas pede rear wheels. I do the same on my TLT but with Pede front wheels.
Natedog is online now   Reply With Quote
Old 10-16-2007, 12:05 AM   #7
Not to hijack this thread, but I also spun a hex just today. So, I'm wondering what's better, in terms of longevity for both the hex, axle and the wheel, plastic or aluminum hexes?
I mean, while aluminum hexes would never suffer damage when a wheel spins on 'em, does it tear up the wheel that much worse, and does it increase the frequency of broken axles/stubs?
Do you spin a hex more often with aluminum or plastic?
I was just thinking that with the forces we put crawlers under, maybe it's better to run softer, plastic hexes, so that the joint between the wheel and hex acts like a "fuse" of sorts, preventing the breakage of more expensive (and harder to repair on the trail) parts up the line?
Or am I stupid and in need of a good beating?
JavelinSST390 is offline   Reply With Quote
