Thread: reverse chassis
Old 10-14-2007, 03:56 PM   #1
Default reverse chassis
hi all,
i've seen more and more people are doing this mod, does someone have a step by step to this mod please as i would like to do it to mine, just not understanding what i have to turn around.....
thanks in advance...
cheers tony...
tony1 is offline   Reply With Quote
Old 10-14-2007, 04:20 PM   #2
Read all of this thread.
It should help...
how do i reverse my wk
raytard is offline   Reply With Quote
Old 10-15-2007, 07:48 PM   #3
It should help...
cheers thanks ray...
Old 10-15-2007, 11:42 PM   #4
hi all,
ok another stupid question, when you guys are reversing the chassis you swap the front rear axle. why cant we just reverse the motor wires like we do and put the steering servo on the rear axle, would that be alright.
if not can someone please explain..
thanks in advance..
cheers tony.....
Old 10-16-2007, 12:13 AM   #5
Originally Posted by tony1 View Post
hi all,
thanks in advance..
cheers tony.....
Not unless you want it to steer like a forklift I.E. Rear steer only.
But the solution to that is simple. Just take the servo mount, with the servo still on it, out of the chassis, remove the servo saver, and flip it 180 degrees.
Now, flip the whole mess over so the servo is pointing up, with the servo saver on the same side of the truck as the steering arms. Now just hook it all up the same way it was, but with the top plastic steering link pointing towards the rear.
And there ya go. Servo in the rear, stock steering set-up!
Remember that the steering lever on the side of the transmission has to be kept on the side it was originally on, the left side, as viewed from the rear of the truck, to get all of this to work.
Now, in order to get full travel of the steering from left-to-right, you'll need to make a longer steering rod that goes between the two steering levers. I just replaced the stock steering rod with a piece of longer 6-32 allthread. The length you need depends on your wheelbase.
Also, consider taking the time while you have it apart to replace the stock servo and servo-saver. The stock pieces are JUNK!!!
Hope this helps!
JavelinSST390 is offline   Reply With Quote
Old 10-16-2007, 12:29 AM   #6
JavelinSST390
thanks for your info javelin,
what i ment as well is to swap the body as well, if that was the case it should steer the same as it was standard, the only diff is the battery at the front...
thanks for your help..
cheers tony...
Old 10-16-2007, 08:05 AM   #7
I just did this,removed the lower links and the upper links at the chassis, and simply put the front axle, with the servo under the battery end and the rear axle under the "front" of the chassis. only problem i had was the servo hit the underside of the battery box when the suspention was fully compressed, so i moved the top of the shocks to the holes near the shock/body mount where the stock handle thing was, by the esc. took care of that! you probbly have this figured out by now, but if not, i hope this helps
WKer84 is offline   Reply With Quote
Old 10-16-2007, 02:40 PM   #8
the best thing to do for the steering is to make/but an axle mounted servo mount (is that redundant redundant?).
That'll make your steering way stronger, more responsive, and you won't have to mess with all that servo mount junk in the chassis. Plus if you make two mounts, it'll set you up for rear steer if you want...
my 2 cents
jbrandt is offline   Reply With Quote
Old 10-17-2007, 10:49 PM   #9
hitman46mod's Avatar
That is why I ordered a servo on axle kit to eliminate this mess.
http://www.ckrccrawlers.com/shop/ind...products_id=23
hitman46mod is offline   Reply With Quote
Old 10-18-2007, 05:56 AM   #10
hi hitman,
thats right thats what im trying to say, put this on your rear axle, reverse the motor and the body and there you have it reverse wheely king....
please correct me if i'm wrong..
thanks in advance
cheers tony.....
Old 10-18-2007, 12:22 PM   #11
hey hitman, your gona have a problem with that mount hittin the chassis, my buddy had one. there easy to make and you can make it low-profile so it dont hit. WAY less$$$!!!
Old 11-03-2007, 02:24 PM   #12
After you extend the WB it is not a problem.
See http://www.putfile.com/pic.php?img=6975359
Old 11-04-2007, 08:39 AM   #13
Off topic, but those are some beautiful dogs hitman46mod. The WK looks good too. lol
Maggster is offline   Reply With Quote
Old 11-04-2007, 11:35 PM   #14
Nice WK hitman, the Husky is beautiful!
So Tony, how did it work out for you?
BigBoy is online now   Reply With Quote
Old 11-05-2007, 04:37 AM   #15
hi bigboy,
the reverse went great, jst changed the steering, cut the steering box to suit.
done this also to my boys wheely king as well.
in the next four days i'm going to extend the chassis...
cheers tony...
Old 11-05-2007, 05:01 PM   #16
post some pics when you do.
hi bigboy,
cheers tony...
countryboy4life is offline   Reply With Quote
Old 11-12-2007, 12:39 PM   #17
Couldn't you just put steering on the rear axle put the rear lock out on the front axle and switch the tranny around backwards and the body.
Old 11-12-2007, 06:09 PM   #18
yea it would be easier
bigblazerboy is offline   Reply With Quote
Old 11-13-2007, 01:32 AM   #19
That's what I did, but I've considered going to a forklift steering
BJoe is offline   Reply With Quote
Old 11-13-2007, 10:03 PM   #20
all i did since my steering is on the axel, i took the steering off and put it on the rear axel, then put the reciever where the esc was and put the esc where the reciever was, then reversed my remote controls and done,
whitetrashxj is offline   Reply With Quote
