Thread: tamiya suspension stays
Old 10-15-2007, 10:17 PM   #1
Default tamiya suspension stays
hi all,
does anyone know where i can get these from, i feel like i have tried evry where just can't seem to find them, tried nearly evry shop here in aus to no luck,
thanks in advance..
cheers tony...
tony1 is offline   Reply With Quote
Old 10-16-2007, 07:33 AM   #2
have fun. i have been looking for a couple of months until i made my own
juststartin is offline   Reply With Quote
Old 10-16-2007, 07:42 AM   #3
Crawling is a fad...
Nerve's Avatar
Tony1,
I checked with my LHS this past weekend on them and they said that they were no longer available. Time to get creative or find an alternative...
EDIT: I was searching for those myself, then I couldnt remember where they were even used. So I went searching on here and found this thread CLICK HERE to figure out where/how they are used again. Then realized I shouldn't really need them at all if im using this aluminum part in its place WK Billet Upper Mounts
Hope it helps ...
Nerve is offline   Reply With Quote
Old 10-16-2007, 09:54 AM   #4
I ordered mine from Tower Hobbies...
WK_Krawler is offline   Reply With Quote
Old 10-16-2007, 11:52 AM   #5
goo
I have been keeping my eye on them for a while now and the expected arrival on tower hobbies keeps getting pushed back. I just took the advice from someone else's post and bought some aluminum C Channel 1/4 inch and made my own. They are a bit sloppy, but it gets the job done.
I'm going to post my build one of these days when i get my crawler finished and i'll get a pic of the ones i made. But i'm going to keep my eyes open for those because they look nicer than the ones i did (my metal working abilities suck).
goo is offline   Reply With Quote
Old 10-16-2007, 12:19 PM   #6
these might also work BUT IM NOT 100% SURE. they look like they would:
http://www.rcpcrawlers.com/product.p...&cat=29&page=1
BrandonW is offline   Reply With Quote
Old 10-16-2007, 12:24 PM   #7
goo
Yeah, i looked at those as well. The top screw hole would work fine (if you have a servo mount on the axel for example), but the bottom one (that needs to screw into the axle housing) didn't seem like it would work all that well without some modification because the screw would need to go in from the angled side. That's just my take, and since i'm very new to all this...take it with a grain of salt .
EDIT: I was just thinking that it would work if you just raise the position where the links mount up. In other words, just extend that portion of the mount up a bit so you could have the hole for the axle housing screw, and have two additional holes for the upper link mount. I don't know how this will effect the dynamics of the suspension though.
This is what i was referring to, the "extension" i mentioned is highlighted in yellow. (not to scale! do not use, just for illustration purposes):
