| | #1 |
| Newbie Join Date: Jun 2007 Location: Wappinger Falls
| This post is for both "stretch" and "Double J" Took all the stock parts from my stretched wheelie king and put it on "Da Bull" chassis http://www.rccrawler.com/forum/showthread.php?t=51442&highlight=Double. As you can see its more a super class than a 2.2. It measures in at 14". If i decide to make new links then it will go back to being a 2.2. ![]() I use the rig for trailin/crawlin. I mounted the WK tranny on its side and used a piece of plastic for the electrics tray. ![]() ![]() After reading a post about weighting rigs i decided to make my own batter mount for the side of chassis. I figure it will off set the weight of the motor hanging out of the opposite side and help lower the COB making it less likely to tip over on high inclines. My stock shocks are still flipped with internal limiters (appox 3mm wide), we'll see how it affects my clearnce. Makes for lower COG with out my bottom hanging down. ![]() ![]() ![]() Don't know how it will do crawlin on its side! For those of you who still have some stock parts..see how i used the old shock/body mounts on the chassis to mount my body. Hope you guys like it. ![]() |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jul 2007 Location: jonesboro
| man i like that chassis, i might have to pick one up for my WK |
| | #3 |
| Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
| great looking ride. where did you get the servo mount and battery holder? i need one for mine? if you know anyone that makes them, send them my way. thanks |
| | #4 |
| Quarry Creeper Join Date: Jun 2007 Location: Sacramento
| the battery holder and servo mount look home made to me... I like the rig. did you have to get extra long drive shafts? which ones did you use? Iin the process of designing/building up a new chassis based off a SW3, but was going to be lazy and not shorten the links off my 12.5" WK , and just get longer drive shafts... I also like how you used the stock body mounts. I'm trying to "engineer" a way to do that on my 'in the works' chassis. I take it the chassis is hte same width as stock? Mine will likely end up a bit wider than stock so I'll have to use spacers or something. |
| | #5 |
| I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| Thread Tools | |
| Display Modes | |
