Thread: Ti plate source?
Old 10-23-2007, 02:11 PM   #1
Default Ti plate source?
Wasn't sure where to post this, so since I'm building a WK chassis, here goes:
Anybody know where I can find a (relatively) cheap source for Ti plate? I want to build a plate type chassis and I'm trying to decide if I want Aluminum, Ti, or Carbon Fiber. I've seen aluminum 12"x12" sheet for around $16, CF 3mm thick sheet for $45, and Ti for $330!!!! (ack!!)
Is Ti REALLY that expensive or is there another source (or perhaps a lower grade Ti) for cheaper? If that's really how much Ti costs, I think my decision has been made for me (CF)...
thoughts?
jbrandt is offline   Reply With Quote
Old 10-23-2007, 02:34 PM   #2
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Titanium is definitely not cheap. Good thing about it though is that if you were going to use 1/8" alum or CF, you could get away with about half that thickness in Ti due to it's stiffness and strength.
Offroader5 is offline   Reply With Quote
Old 10-23-2007, 03:27 PM   #3
Titanium will be very slow and difficult to cut. It will also be heavier than aluminum and carbon(if used in the same proportions).
Check eBay they have a few auctions selling sheets in various dimensions.
I would look into buying a sheet of 7075-T6 and call it a day. It will be the cheapest of the three and the easiest to cut.
If you are ever in the LA area I would also check out http://www.calaerosupply.com/ They have a good scrap section.
_BEN_ is offline   Reply With Quote
Old 10-23-2007, 03:36 PM   #4
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Cutting Ti sucks. Cutting CF laminate sheet sucks too. I would suggest you stick to aluminum.
JohnRobHolmes is offline   Reply With Quote
Old 10-23-2007, 03:43 PM   #5
binaryterror's Avatar
Titanium bends more than 7075 Aluminum. Unless you are building in some torsional flex Titanium is just a bad choice.
binaryterror is offline   Reply With Quote
Old 10-23-2007, 03:55 PM   #6
Yeah also if you want to put bends into your design I would stick with a 5000 series aluminum.
Another site.
http://www.aircraftspruce.com/menus/me/index.html
Old 10-24-2007, 10:43 AM   #7
thanks for all the input guys,
I was mainly looking at Ti for the bling factor, but it's just not worth it. I still may try the CF, at $45 for a laminate sheet, it's cheap enough to experiment with. Also for the bling factor...
Old 10-24-2007, 10:52 AM   #8
Binary, Ti bends LESS, its very stiff. Its a very tough material to work, bend, drill and machine. Jbrandt, cutting laminate is easy, use an electric wet tile saw with a diamond blade, if you have one handy, if you dont use a friends. Anything else you have a big mess and less clean cuts.
Usmc8541 is offline   Reply With Quote
Old 10-24-2007, 11:49 AM   #9
Offroader5's Avatar
Also a good idea to wear a mask and glasses when cutting CF
Old 10-24-2007, 12:00 PM   #10
True, but the water helps capture the pesky shards.
