Thread: Crawling speed controller
Old 10-26-2007, 08:52 AM   #1
Default Crawling speed controller
What would be a good speed controller for crawling in a wheely king for under $50? I was looking at the Traxxas xl-10, is it any good? Thanks.....
LST022752 is offline   Reply With Quote
Old 10-26-2007, 06:11 PM   #2
Moped V16r... 3amps at the BEC!
drcooper is offline   Reply With Quote
Old 10-26-2007, 06:15 PM   #3
you might look for a used tekin rebel III on ebay, or somthing, but not much for under $50 as far as new. most all esc will "drive" your rig without over heating, given you are running 55t+ motor, but it will not have desireable crawler features like, 0 delay foward/reverse, and drag brake, plus most general esc's only supply 4.8v and 1.5 amps to your servos, as to most of the "crawler" esc's provide 6.0v and 5amps
stonedaddiction is offline   Reply With Quote
Old 10-26-2007, 06:39 PM   #4
I was also looking at a Novak XRS. Would it be any good?
Old 10-26-2007, 06:46 PM   #5
this is probably one of the most vital things on a crawler, I would suggest saving your pennies, and going with a mamba or a novak rooster crawler ed, i have a rooster and am very pleased with it. it will be worth it down the road
Old 10-27-2007, 06:26 AM   #6
Thanks for the help. But it went two days ago and I'm probabily gonna get someting my LHS has because I need it asap.
Old 10-27-2007, 05:12 PM   #7
I ended up getting a Duratrax Intellispeed. So far I like it.
Old 10-27-2007, 06:52 PM   #8
if you wanted a waterproof you could get a L.R.P. Quantum Runner Reverse 18T. Nick told me about it he uses it on his wk still i think.
countryboy4life is offline   Reply With Quote
