| | #1 |
| Quarry Creeper Join Date: Oct 2007 Location: Ohio
| I want to extend the wheelbase on my Wheely King. I want to extend it to about 11-11.5 inches or so. I dont want it to be 12.5. What can I use to do this? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Jun 2007 Location: Fairfield
| i just extended mine today but i just did the rear so my weight is further foreward.its at about 11.5 inches...all you need is to have some engineering abliility and you dont have to use the same measurements everyone else uses. check it out http://www.rccrawler.com/forum/showt...143#post899143 hope this helps! |
| | #3 |
| RCC Addict Join Date: May 2005 Location: Roy/Eatonville, WA
| | #4 |
| Quarry Creeper Join Date: Aug 2007 Location: Lumberton
| You could do like nick did his links were bulletproof. His forum is with the pic of his truck. Got to the WK gallery and on the first page look for a red suburban. I'll try to get you link soon. |
| | #5 |
| Newbie Join Date: Oct 2007 Location: SW WA
| I've also use the Traxxas links. They have a few different sizes (84,102, 112 mm). And just use a spacer and longer screw for the upper link. I had a couple of the shelf, and they work fine. |
| | #6 |
| Would it work if I used these on top http://www3.towerhobbies.com/cgi-bin...?&I=LXHFV7&P=Z with http://www3.towerhobbies.com/cgi-bin...?&I=LXGKG9&P=7 and these on top http://www3.towerhobbies.com/cgi-bin...?&I=LXHFV9&P=Z with tmaxx driveshafts? Last edited by LST022752; 10-29-2007 at 09:41 AM. |
| | #7 |
| Your links to tower don't work. |
| | #8 |
| Yup, that's the 102's that I've used. If you put an X after the part # you'll get them in red and stronger |
| | #9 |
| But use the Revo 4951x driveshafts and if you want to step up, get the 4928X yokes (straight bolt on). You'll have to shorten the driveshafts a little. |
| | #10 |
| | #11 |
| Rock Stacker Join Date: Jul 2007 Location: Albuquerque
| Thread Tools | |
| Display Modes | |
