Thread: WK pinion options???
Old 10-28-2007, 01:06 AM   #1
Default WK pinion options???
I am wanting to swap my pinion gear to a 15 or 16 tooth and keep the stock spur. Is this possible?
When looking at it, it seems the motor is almost bottomed out against the tranny in stock form.
Do I have to bring the spur up to 96 to get the smaller pinion to fit?
edman87k5 is offline   Reply With Quote
Old 10-28-2007, 07:27 AM   #2
Not sure. You would have to try it to find out.
hpi123 is offline   Reply With Quote
Old 10-28-2007, 11:10 AM   #3
I could only fit a 15 or 16 with the 96 spur. Though if you're having problems getting a 96 spur, it's pretty easy to grind off the top of the transmission and slot the motor plate slightly to get the motor lower. Doing that would probably let you get a 15 on the stock spur. It let me get a 12 pinion on the 96 spur.
S1NN3R is offline   Reply With Quote
