Thread: My Wk rig
Old 12-15-2007, 02:57 PM   #1
Default My Wk rig
I just put the water sealed box thing in
jus have the electronics in there so they do not get wet
i have 13/96
sappose to have new motor but not here
i have the alluminum steering links
and servo mount
and Hitec 645mg servo
i have beadlocks with mudslingers
dont really like them probably going to switch to something different
wheely king 69 is offline   Reply With Quote
Old 12-15-2007, 04:20 PM   #2
What box did you use for the electronics? If you can, get the battery down lower. It will help lower your center of gravity considerably.
karlos is offline   Reply With Quote
Old 12-15-2007, 04:25 PM   #3
i just found some box laying around the house and used it
it works good because i dropped it in the pond and it is still working fine
ummm i know about the lowering the battery but i just dont know where to put it
Old 12-15-2007, 04:37 PM   #4
Now that you have your steering mounted on the axle you could swap it to the other side and swap wires on the motor to correct it on your control. Then you could put the battery back in it box.
Old 12-15-2007, 04:57 PM   #5
nahh i think ima just stay with this and then ima get the kit to stretch itt
Old 12-15-2007, 08:06 PM   #6
I would flip the chassis around so you can use the battery box, your COG is to high.
Shaun is offline   Reply With Quote
