| | #1 |
| Pebble Pounder Join Date: Dec 2007 Location: roanoke,tx
| is making your own links better than using the traxxas turnbuckles? are they stronger and less likely to bend?i'd like to start gathering parts,so i'd like to do it right the first time. |
| Sponsored Links | |
| | #2 | |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
The last set I made for my WK, I used 1/4" acetal TUBE sleeved over some 8-32 all thread. It was so easy. I cut the tube to length, ran a drill bit down it lengthwise to open up the inside just a hair more, and then slid the all thread right down through it. Then just screwed on some Revo ends. You can get acetal tube for like $4 for a 5 foot piece. How long do you need your links to be eye to eye? I was lucky with mine. I could buy precut pieces of 8-32 all thread at 3" long and that's the exact length I needed to get the 12.5' wheebase with my Widow chassis. I think the all thread came in a box of 50 for like $6. I know of a place too that you can get the Revo ends for under $7/pack instead of paying the $9 a pack that they seem to sell for everywhere. Wheww, that was a longer post than I meant it to be | |
| | #3 |
| Newbie Join Date: Nov 2007 Location: West Hills
| yeah tube over allthread is the way to go. the traxxas links are crap comparitively. |
| | #4 | |
http://cgi.ebay.com/Traxxas-Rod-Ends...sid=p1638.m118 | |
| | #5 | |
| Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
I normally use 4-40 all thread sleeved with Acetal. Seems to work good. But I also feel that the Traxxas turnbuckle work very good and the fact they are ready to bolt in makes them good for the newer guys. You can also use arrows to make links, do a little search and the post should be somewhere around here. I've used pretty much everything for a link. My final opinion is 4-40 all thread sleeved with Acetal. | |
| | #6 |
| Rock Stacker Join Date: May 2007 Location: Lousyana
| Like above state. Stronger, maybe. Better, depends. The traxxas ones are pretty strong but if you need custom ones, you will probably have to fab your own. Its all what you want to do. I use some 1/4" aluminum and drill and tap mine. then thread with some 8-32 all thread and cut off what I need. |
| | #7 |
| I wanna be Dave Join Date: Jan 2006 Location: CA
| Traxxxas T-Maxx and Revo links work great and both are plenty strong...I've never broken or bent either on a crawler. |
| | #8 | ||
With 4-40 though, you end up having to use the standard Maxx rod ends (the smaller one's). For Revo ends (turnbuckle & pushrod ends...not shock ends), you need a minimum of 4mm or 8-32 all thread. | ||
| | #9 |
| Rock Crawler Join Date: Jul 2007 Location: Rectalville
| I make mine from UNPLATED 8-32 allthread (the unplated part comes in in a second) with three different sizes of K&S aluminum tubing over it for sleeves. I don't know what the other two sizes are, but the outside sleeve is 1/4", and the other two pieces are a very nice slip-fit inside of those. Then I use the SHORT Revo rod ends. (you could use the long ones, but I prefer the shorts because they look better) Now, the reason you need UNPLATED allthread is because the smallest size of aluminum tubing is not just a slip-fit over the allthread. You actually have to THREAD the allthread into the tubing. And PLATED allthread won't fit without running a tap all the way down thru the tube (almost impossible) while the unplated stuff is just small enough and will cut it's own threads going in. Done this way, these things are SUPER strong. I can't bend 'em by hand, and I've only ever bent one, and that took tumbling down a flight of concrete stairs! |
| | #10 |
| Newbie Join Date: Sep 2007 Location: millersburg
| I have always wondered. Why do people drill and tap into solid aluminum to put althread instead of just using a dye to cut the threads right onto the aluminum. |
| | #11 | |
Not to mention....the all thread will be stronger than if it was just aluminum threaded directly into the rod end. | |
| | #12 | |
| Rock Stacker Join Date: Jul 2007 Location: Albuquerque
That would definately be easier. I personally used the carbon fiber hunting arrows for my links. They are super light. The difference with the arrows is you use inserts in each end, which are tapped for 6-32 or 8-32 (I can't remember). I just cut the heads off of some screws and install the hyme joints on the ends. Here is an old pic, but it shows a link. | |
| | #13 |
| Newbie Join Date: Oct 2007 Location: Louisiana
| My links will never bend! 1/4" solid rod, drilled and tapped for 6-32 insert( screws with head cut off) all this was free/ laying around Bought a pack of traxxis ends and still have some extras the 6' sections of allthread are under $3, but I didn't have a chance to get to the hardware store until after I made the links. I did buy a 6' stick of 4-40 for my steering for $1.79, sleeved it with blue plastic tubing |
| | #14 |
| "Because if using .250" diameter stock (most widely used), the material that has to be removed at the end of the aluminum rod in order to die it down to fit 8-32 or 4-40 is far more than if you just tap out the end. Try taking a die meant for 8-32 and run it down onto the end of a piece of .250" aluminum rod...then you'll understand" If it is only the work it takes about 10 min. per link. Jigsaw, vice grip, three dyes (ending in 5 mm x 80), large revo rod ends. Just wondered if this had been tried before and failed for a reason or why everyone is so quick to shut it down. I found it was a simple way to make links for a newbie. |
| | #15 |
| Newbie Join Date: Sep 2007 Location: franklin,tasmania
| I have used a few different things like solid tapped aluminium rod that has been tapped with allthread rod, 5/32 allthread rod with plastic garden dripper lines or aluminium tube. my favourite at the moment though is to use 1/4 hardened copper pipe that i salvaged at the local tip |
| | #16 |
| Newbie Join Date: Dec 2007 Location: bethlehem
| i found out after lots of math that u can tap 3/16 aluminum rod with an .049" wall with 4-40 easily the tap drill bit measures .088"dia. the i.d. of the tube is .077 so u just have to drill it out a little bit nd u can tap it perfectly... i can figure out other size rod if u want meh to. |
| | #17 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| I think a few of you are confusing rod & tube. Rod is solid stock and tube is hollow. I used Dubro 6-32 rod ends and ran some 6-32 all-thread through 1/4 .49 wall round tube. On the chassis end I replaced the smaller screws with more 6-32 all-thread through the whole chassis and sleeved that as well: |
| | #18 | ||
| | #19 |
| opps i meant tube |
| | #20 |
| Newbie Join Date: Dec 2007 Location: bellevue
| I make and use Carbon fiber links,I buy the carbon fiber tubes use 440 all thread and traxxas links,I have had no problems and they are super light. |
| Thread Tools | |
| Display Modes | |
